Hi ..I have a NTSC DVD and I want to send a copy to a friend but he would like it in PAL:....can anybody recommend
a program to do this ....Many Thanks HK
Chance are your friend can actually play the NTSC version.
If I had to do this type of job I would start by looking at the source material. If it is true interlaced 29.970 fps NTSC I wouldn't bother. If it is progressive 23.976fps NTSC then I would use VOB2MPG to get the contents out to sperate files, then put them through AVS2DVD to do the conversion, then author using my favourite authoring tool.Read my blog here.
Hi..Thanks for your reply ...You are quite right ...No doubt he would have no trouble playing a copy of the NTSC version... but I thought I would get smart and try and do a DVD with not only the original music DVD but some extra clips I have by the same artist..Heres what I have done so far since my posting..I Ripped the DVD with DVD Decrypter...and am now re-encoding the VOB files to PAL (720x576 25fps ) using "Super"...Then what I do next is unknown???..I wonder if I can join all the VOB files and drop them into an Authoring Tool..and perhaps add chapters menu etc .Its basicly hit and miss with me .. I am using this as a learning experience..Yesterday the VOB files I encoded that I converted were terrible and now I know why ...Instead of ripping the DVD I started playing around with the VOB's that I copied from the DVD Video_TS folder...I presume this makes me pretty dumb ..I never even checked the VOB's by playing them!!! I have checked the ripped files with Gspot and they are 29.970 fps...
Anyway thankyou very much for your reponse ..its very much appreciated..MK
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
convert pal dvd to ntsc, but different
By atomicrabbit in forum EditingReplies: 5Last Post: 12th Jan 2008, 04:48 -
What programs convert a DVD from/to PAL/NTSC?
By Des in forum Video ConversionReplies: 10Last Post: 14th Nov 2007, 11:00 -
convert pal dvd to ntsc format?
By butt_crack in forum Newbie / General discussionsReplies: 2Last Post: 17th Aug 2007, 00:26 -
How to convert PAL DVD to NTSC?
By tomterrifk in forum Newbie / General discussionsReplies: 3Last Post: 18th Jul 2007, 16:35
