I am new to mAVCHD, and having a horrible time trying to create a simple menu. My files transcode successfully, but no menu is created. My example below is for a SD-DVD because I can test it faster rather than wasting time encoding to just see if the menu works. In the log it shows: Encoding motion DVD menu...
[17:46:33] SD-DVD menu preparation did not succeed. I had the software set to static menu, not motion, but the log always says "motion" . I don't know what I am doing wrong, or if I am missing some software that needs to be installed. I have multiavchd.exe version 4.1, ffdshow, haali media splitter.
Its probably something simple, but I've spent hours googling without success.
Thanks for any help
[17:42:49] Initialising...
[17:42:49] Checking for new version...
[17:42:49] You have the latest build.
[17:42:50] Consistency check finished!
[17:42:50] Initialization finished. multiAVCHD is ready!
[17:42:50] 2 years and 259 days since multiAVCHD was published.
[17:42:50] 462 people supported it with donations
[17:42:50] and you are the 3259925 one to launch the program...
[17:42:50] Support multiAVCHD to extend its features and keep it going!
[17:42:50] multiAVCHD.dat version: [04010767]
[17:42:59] Project name: multiAVCHD
[17:42:59] Project loaded: (C:\Documents and Settings\Owner.GATEWAY\My Documents\My Videos\TEST.mpf)
[17:42:59] Project created with build 770 (11/09/2011 16:22:42)
[17:43:20] Checking for available space and drive types (FAT32/NTFS)...
[17:43:24] Destination [c:]: NTFS, 218481.62 MiB (213.361 GiB) free space
[17:43:24] Temp folder [c:]: NTFS, 218481.62 MiB (213.361 GiB) free space
[17:43:24] Log started for multiAVCHD v4.1 (build 770)
[17:43:24] Selected output mode: DVD player (DVD R/RW disc)
[17:43:24] Processing one title...
[17:43:24] Existing c:\multiAVCHD\AVCHD\ cannot be used as destination folder!
[17:43:24] Output will be written to: c:\multiAVCHD\AVCHD-20110911-174324
[17:43:24] Processing (C:\Documents and Settings\Owner.GATEWAY\My Documents\My Videos\HD Videos00012.MTS)...
[17:43:24] This title is marked for reencoding / uncropping...
[17:43:24] Encoding process may take 10 min to 10 hours, so be patient...
[17:43:24] *** Initiating video encoding:
[17:43:24] *** Original : 1920x1080
[17:43:24] *** Crop : 0
[17:43:24] *** Resize : 720x480
[17:43:24] *** Uncrop to : 720x480
[17:43:24] *** Sharpen : 0
[17:43:24] *** Bitrate : 8000 kbps
[17:43:24] *** Frame rate: 23.976 (29.970)
[17:43:24] *** Profile : SD-DVD (MPEG-2)
[17:43:24] *** Encoding : Pass one - content: [00:00:16] (MPEG-2 encoder: lavc)
[17:43:57] *** Close to completion - closing preview...
[17:44:53] *** Speed P1 : 4.59 fps (elapsed: 00:01:28)
[17:44:53] *** Encoding : Pass two
[17:46:12] *** Speed P2 : 5.12 fps (elapsed: 00:01:19)
[17:46:12] *** Speed : 2.42 fps overall (elapsed: 00:02:47 - Realtime x 0.1)
[17:46:12] *** Speed : 2.42 fps (elapsed: 00:02:47 - Realtime x 0.1)
[17:46:12] *** Transcoding successful!
[17:46:13] Detected video: ID#0:V_MPEG-2 720x480, fps=23.976
[17:46:13] Display properties: 853x480 (AR:1.78)
[17:46:13] Detected subtitles: ID#4608:S_HDMV/PGS Language: und
[17:46:13] Total of 1 tracks found in this file.
[17:46:13] No audio tracks found!
[17:46:13] Creating SD-DVD structure...
[17:46:15] Demuxing 1 subtitle and 1 audio tracks...
[17:46:15] Converting subtitles to DVD format...
[17:46:15] Converting [HD Videos00012.track_4608.sup] to PGS/SUP (java:BDsup2sub)...
[17:46:16] !!! Last imported subpicture: 1/1 02
[17:46:16] *** Imported subpictures: 1/1 02
[17:46:16] Conversion failed!
[17:46:16] Processing 1 audio tracks...
[17:46:17] Audio processing completed!
[17:46:17] Applying pulldown...
[17:46:18] Title contains: 1 audio tracks and 0 subtitle tracks
[17:46:20] *** Extracting menu background video!
[17:46:20] *** Done!
[17:46:20] *** Encoding motion DVD menu... <-----------------
[17:46:33] SD-DVD menu preparation did not succeed! <-----------------
[17:46:33] Authoring DVD structure (muxman)...
[17:46:44] SD-DVD muxing completed!
[17:46:44] SD-DVD title saved:
[17:46:44] c:\multiAVCHD\AVCHD-20110911-174324\[DVD]\20110205 22-04-14 (HD Videos00012)
[17:46:44] Compilation contains 1 (HD)DVD titles and no AVCHD/Blu-ray titles!
[17:46:44] Preparing menu pages...
[17:46:44] Setting main menu for 0 titles...
[17:46:44] Selected TV system: [NTSC]
[17:46:48] Done!
Compilation summary:
Format: DVD player (DVD R/RW disc) (mixed with DVD)
1. 1 HD/SD-DVD titles
Output size : 17 MiB (0.017 GiB)
[17:46:48] c:\multiAVCHD\AVCHD-20110911-174324 folder created (AVCHD/Blu-ray output)!
[17:46:48] Burn its CONTENTS to DVD R/RW UDF 2.50/2.60 disc!
[17:46:48] Compilation contains HD-DVD/SD-DVD titles placed in [HD-DVD]/[DVD] folder.
[17:46:48] Burn each HD-DVD/SD-DVD title folder contents (both HVDVD_TS and VIDEO_TS for HD-DVD) to a separate DVD disc.
[17:46:49] Select folder/name for ISO file...
[17:47:10] Using ISO mode / destination: C:\Documents and Settings\Owner.GATEWAY\My Documents\My Videos\TEST.iso
[17:47:10] Launching ImgBurn...
[17:47:32] You may now remove temp folder (c:\multiAVCHD\_TEMP\multiTEMP-20110911\).
[17:47:32] multiAVCHD finished in 247.984 seconds (00:04:07.984)!
[17:47:32] End of log.
[17:47:32] Cleaning up...
[17:47:32] Done!
[17:47:33] DELETE EXCEPTION: Should not touch folder! (c:\multiAVCHD\AVCHD-20110911-174324\AVCHDTN\)
What's your player? The reason I ask is that I have a Momitsu BluRay player (I believe this was sold under a different brand name in Canada) and it won't play anything that multiAVCHD creates. If you haven't done so already test your disc in a PC to make sure that it really has a problem.
My player is a Philips BluRay Player. It's irrelevant at this point, as I outputted the results to an iso file, and loaded onto a virtual drive and played it on Roxio Cineplayer. The encoded file played perfectly fine, but there was no menu. Previously, I experimented with an AVCHD burn to DVD disk and ticked off the Welcome screen. This I put into the Philips player, and a screen came up on the TV asking me to choose, Music, Photo, or AVCHD. When I chose AVCHD the welcome screen played, and the tv screen then went blank. On the player the information screen showed "MENU" but I couldn't do anything with the remote control, or any of the buttons on the player.
multiAVCHD Menu
By catracho2009 in forum Authoring (Blu-ray)Replies: 11Last Post: 29th Aug 2016, 17:18 -
MultiavcHD menu problem...HELP!
By digitalfreaknyc in forum Authoring (Blu-ray)Replies: 7Last Post: 12th Jan 2012, 06:06 -
multiAVCHD Setup Menu
By catracho2009 in forum Authoring (Blu-ray)Replies: 14Last Post: 29th Jul 2010, 12:39 -
multiavchd, create menu?
By volam1 in forum Authoring (Blu-ray)Replies: 4Last Post: 12th Jul 2010, 13:31 -
TMPGEnc Author Version 2.0 - Unable to make a DVD with a motion Menu
By tug_hill2 in forum Authoring (DVD)Replies: 5Last Post: 28th Sep 2007, 00:37
