so, on linux atm i use ffmpeg to convert content to my psp1000.
i use this command:
ffmpeg -i input.avi -r 29.97 -b 564k -ar 48000 -ab 128k -s 368x208 -f psp output.mp4
now i want to add a pile of mpeg files that have no audio track, the .mpg needs an audio track of some kind or ffmpeg wont accept the file. (presumably cos of the psp in the command.
what command can i add to the conversion if say i have input.mpg which equals 00:10:32:35 for example
i want to ffmpeg to generate the exactly amount of silence and combine it with the input.mpeg
any help much appreicated
Hi
Try it with a command like this:-
See if the result will play on your psp1000.Code:ffmpeg -i input.avi -vcodec libx264 -r 29.97 -b 564k -s 368x208 -an output.mp4
ok i will try that, probably get time to try it monday evening. thanks
Anyone Can Help to Convert This Preset to FFmpeg Command Line?
By raymng in forum Video ConversionReplies: 2Last Post: 26th Feb 2012, 12:11 -
ffmpeg / H264 (need help to build an optimized command line)
By iwiiiiiiiiii in forum Video ConversionReplies: 13Last Post: 22nd Oct 2011, 10:41 -
ffmpeg tga to x264 command line ?
By krohm in forum Video ConversionReplies: 71Last Post: 6th Jul 2010, 02:01 -
Using ffmpeg command line to convert a .vob(DVD) to avi/mpeg
By alfo666 in forum Newbie / General discussionsReplies: 1Last Post: 13th Sep 2009, 03:14 -
Definitive command line for ffmpeg conversion to ipod from tivo?
By orev in forum Video ConversionReplies: 1Last Post: 16th Jan 2008, 13:29
