Hello.
i am looking for a program that will encode my videos with these properties:
general:
extenion: .mpg
format: MPEG-PS
video:
ID: 224(0xE0) - i don't know what it means
video format: advanced video codec (AVC)
format profile: Main@L3.0
CABAC: yes - i don't know what it means
reframes: 3 frames - i don't know what it means
GOP: M=2, N=13 - i don't know what it means
width: 720
height: 480
aspect ratio: 3:2
frame rate: 29.970
standard: NTSC
color space: YUV
chroma subsempling: 4:2:0
bit depth: 8
scan type: progressive
audio:
MPEG audio
version 1
layer
bit rate: constant
sampling rate: 48 khz
this is the video properties that hadware produces, and it 100% knows how to play files with these properties.
is there a program that may help me?
thank you.
hello.
i found a PDF file about the encoded/decoder chip:
http://ms-n.org/DataSheets/Qpixel/QL201B_Product_Brief_031207.pdf -
it would be easier if you just said what device the chip is in. depending on how the firmware of the device is programed different video and audio can be played. the chip by itself can't play anything.
I do not know how the firmware of the device is programmed. the device it a black box for me.
all i know is that it can play the same video it records. the video properties i wrote here are of the video it records.
i just tried using MediaCoder. i managed to make file with exact same prperties, except GOP parameter in video (did'nt find it in MediaCoder), and audio is mpeg layer 2 instead of layer 3. do you know how to make mpeg layer 3 in MediaCoder?
anyways, when MediaCoder finish encoding new file, no program can play it. tried VLC and MPlayer. both programs can play original videos recrded on the device. anyone know what can it be? -
audio - select mp3 in the drop down.
but i'd try handbrake and use the apple universal preset or a ipod one. it should play.
making 264 in a mpeg-ps stream is probably the problem. it's not common. the chip can make and play other formats though.--
Need a little help converting a specific movie file
By Cornholio77 in forum Video ConversionReplies: 2Last Post: 28th Dec 2011, 16:45 -
Cannot Format Specific Options in MKVmergeGUI
By PikachuCLS in forum EditingReplies: 2Last Post: 14th Apr 2011, 17:41 -
need convert to a specific format for a mp4
By james_patageul in forum Video ConversionReplies: 7Last Post: 6th Jul 2009, 05:50 -
Problem Converting Video Format
By jb2135 in forum Video ConversionReplies: 6Last Post: 5th Jul 2009, 15:06 -
Trailers MOV format -- How to decode/demux/trancode to .MP4 ? [Solved]
By vhelp in forum Video ConversionReplies: 27Last Post: 21st Jun 2008, 15:00
