I'm getting the following error when trying to rip one of my DVDs:
Looking at previous reports about this error message on these forums, it looks like the IFO files can prove useful when looking at this error, so they're attached to this post (I hope - first post on here, so hope I've done that right!).Version: VOB2MPG PRO
Build: 3.2.2000
Type: System.IndexOutOfRangeException
Source: VOB2MPG
Message: Index was outside the bounds of the array.
InnerException:
StackTrace: at VOB2MPG_PRO.IFO.x32eac27632acc346.x6c4b20002b48aaf e(UInt32 x2bc0b62708e873bb)
at VOB2MPG_PRO.IFO.x32eac27632acc346.xa3a9daebe1fd5c9 3(String xeadccf02f8622700, Boolean xb909d68cec5e9c0b)
at VOB2MPG_PRO.xfed3de3bc2a8e64d.bOpen_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at DevComponents.DotNetBar.ButtonX.OnClick(EventArgs e)
at DevComponents.DotNetBar.ButtonX.OnMouseUp(MouseEve ntArgs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at DevComponents.DotNetBar.PopupItemControl.WndProc(M essage& m)
at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Can someone help me to get this sorted out?
If you are trying to rip straight from the disc...the only and obvious thing to do next is to rip the disc to your HDD first with something like DVDFabDecrypter - then convert to MPEG with VOB2MPEG.
Are you able to play this DVD in a normal player? I tried opening your IFO file in a DVD player application and it crashed my player. That may be because it couldn't find the video to go along with it, (I don't know much about this) or it may be because the IFO file is corrupted. If you can't play the DVD normally, then that should solve this problem right there.
Vob2Mpg Pro
By varcs in forum Newbie / General discussionsReplies: 2Last Post: 23rd Apr 2012, 01:45 -
VOB2MPG Pro / Win 7 Pro 64-bit Service Pack 1 Problem?
By Rich_A in forum SVCD2DVD & VOB2MPGReplies: 21Last Post: 2nd May 2011, 15:06 -
VOB2MPG v3.o Pro
By sdbowen in forum Video ConversionReplies: 1Last Post: 18th Apr 2011, 20:58 -
Unable to install VOB2MPG or VOB2MPG PRO
By tooc in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 28th Mar 2010, 00:53 -
System.DivideByZeroException in VOB2MPG v3.0 PRO
By mhill64 in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 22nd Jun 2009, 05:20
