I have just downloaded the trial version of Magix Music Maker 17 for one purpose - i have read it has the option to split tracks of audio file, for example, remove vocal track from the rest. Can somebody please tell how to do it? The interface of this program looks nice and easy to use, i see a lot of functions, but miss the one i need most.
It means i misunderstood - the program only can split channels, not tracks...
Sony Sound Forge has a "Vocal Eraser" plug-in, but it's not going to give you a clean karaoke version. It's good if you want to overdub though.
Magix Music Maker 17 appears to be a music creation sequencer program using loops and midi tracks. So you wouldn't be able to use it to remove vocals from an existing audio recording, mp3, wav or whatever. There are a number of programs available to remove vocals like Soundforge, Audition, Goldwave etc - just Google vocal remover software. But be warned it all depends on how the original was mixed as to how well the common material to the stereo tracks can be removed
Remove vocal from a music video or a song
By coxanhvn in forum Newbie / General discussionsReplies: 7Last Post: 1st May 2016, 20:16 -
Magix Music Maker 17 - esseintial function missing
By Artas1984 in forum AudioReplies: 3Last Post: 12th Sep 2011, 13:47 -
simplest way to do this? DVD to MKV and split title tracks.
By ian_g in forum DVD RippingReplies: 4Last Post: 30th May 2009, 05:30 -
Dropped frames when importing Windows Movie Maker video into Magix edit pro
By gom in forum EditingReplies: 1Last Post: 27th Oct 2008, 10:55 -
Replace Background Music with New Music without affecting other tracks
By PaulDHolloway in forum AudioReplies: 3Last Post: 10th Apr 2008, 12:56
