I have a mp4 that does not focus on the specific sound I want.
Is there a free utility that would extract the sound where I can run it through a graphics equalizer then put the video back together again? what would be the general usage steps to do this?
Currently the loudness of the higher pitched sound I want is drowned out by other lower pitched sounds and you can almost cant hear what I want to hear.
Here is the format of the sound from my MP4 video
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Duration : 5mn 31s
Bit rate mode : Variable
Bit rate : 128 Kbps
Channel(s) : 2 channels
Channel positions : L R
Sampling rate : 48.0 KHz
Resolution : 16 bits
Stream size : 5.06 MiB (1%)
Do I have to anything special to get the ffmpeg plug-in into Audacity? I mean, have other utilities I use that utilize ffmpeg, like Super, that use it. I guess what Im asking is how to link ffmpeg into Audacity? When I do this, does this mean I dont need any other utility to separate the video/audio?
Got it figured out.
Using Free Video to Audio converter I can write a WAV file
Using a DAX Eq software (not free) I can adjust the frequency bands and re-write the WAV file
Then Avidamux us able to convert and sub the WAV file to ACC format and then write out the MP4.
Works good.
Thanks for the ideas guys!
Problem with sound - MP4 video from CD
By Ves in forum Newbie / General discussionsReplies: 5Last Post: 27th Jan 2012, 03:43 -
Sony Vegas 9 - MP4 AVC-1 - Sound but no video
By inocent in forum Newbie / General discussionsReplies: 3Last Post: 7th Jul 2011, 15:24 -
How to apply filters to video?
By kaona in forum Newbie / General discussionsReplies: 0Last Post: 13th Apr 2011, 13:59 -
Joining a MP4 video and mp3 sound
By powerkor in forum Newbie / General discussionsReplies: 2Last Post: 4th Sep 2009, 10:22 -
Videonics Video Equalizer VE-1
By abbymat in forum RestorationReplies: 2Last Post: 4th Sep 2007, 22:43
