I have a canopus advc 50 capture card which is a little older model. I was wondering with a new camcorder HDR-FX7 if I would or should get a new capture device? If so, what is recommended?
Transfer video from the camcorder to the compute via firewire. You will get an exact copy of the digital data on the tape. No capture device needed. If you don't have a firewire port get a PCI or PCIe card with one for US$20.
I have the canopus device which already has a firewire port. I did not know if there was anything better than that?
Yes, the ADVC50 has a firewire input that is passed through to the firewire input in your computer. You can use that. When you transfer via firewire you get an exact copy of what's on the tape. It doesn't get better than that.
HDR-FX7 is HDV so it can't/shouldn't be used with the Canopus. Just hook it up directly to the PC.
Why can't it be hooked up to the canopus? It has firewire. If this is true, is there not a capture device to use?
Vaporeon800 doesn't seem to realize the ADVC50 has a firewire passthrough. I'm pretty sure you can use that for HDV transfer. If not, you can just bypass the ADVC50 and go directly to the computer's firewire input.
Looking for capture device, is this what I need?
By V Bot in forum Capturing and VCRReplies: 3Last Post: 21st Apr 2012, 09:16 -
Capture Device
By NMeade in forum Capturing and VCRReplies: 7Last Post: 24th Feb 2011, 17:23 -
What device to use for VHS capture ?
By dazz700 in forum Capturing and VCRReplies: 3Last Post: 17th Mar 2009, 15:18 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 04:31 -
capture device for hd
By jjjamiem in forum Newbie / General discussionsReplies: 2Last Post: 8th Aug 2007, 14:30
