Hello,
I'm trying to capture a DVD with a Stand Alone DVD-Player through HDMI using Virtual Dub.
I have this card http://www.amazon.de/gp/product/B002MRROO4/ref=oss_product
Just because it is a very buggy DVD which I can only transfer properly by transfering it directly. (ripping with for example dvddecrypter not possible)
I followed Cauptain's guide in this thread https://forum.videohelp.com/threads/333860-So-how-do-I-use-VirtualDub-to-capture-from-t...-AverTV-HD-DVR but it didn't work out.
All I'm getting is a black screen. I also think that Virtual Dub is maybe the wrong capture tool since I wanted to capture and save in MPEG2, but at least I want to capture it at all and that's not working. I'm not getting any signal although the HDMI output of the standalone DVD Player is activated properly.
all help is appreciated
thanks
-Gwar
	And if you use the included application to view the HDMI input, what then?
	Driver version? And I don't remember whether Caputain's guide in that thread notes that you need to have the AVer software open when you're capturing with other programs.
 Also make sure that the capture/preview pins are set for PAL if that's what you're capturing.
 http://www.kiva.org/about
  DVI to Component to AverTV HD Express- YPbPr works on HDTV but not AverTVBy asperi in forum Capturing and VCRReplies: 1Last Post: 9th Jan 2012, 10:22
  I have a few questions regarding capturing with AVerTV HD PVR and a PS3.By phenom97 in forum Capturing and VCRReplies: 2Last Post: 22nd Sep 2010, 09:02
  Best Capture Card Under $150?? (AVerTV CaptureHD??)By jenna12 in forum Capturing and VCRReplies: 7Last Post: 1st Apr 2010, 13:38
  capturing xbox pal60 avertv hybrid + fm volar usb A828By ankmorph in forum Capturing and VCRReplies: 3Last Post: 31st Jan 2009, 07:24
  AVerMedia AVerTV Hybrid Volar HX capturingBy kiraly.andras in forum Capturing and VCRReplies: 1Last Post: 13th Sep 2008, 14:17
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
