Im using aimersoft video converter and i changed the fps from 25 to 29.97 will the audio out of sync?
It depends on how it's done. If the framerate is increased by adding in duplicate frames, then the video stays the same length and the audio remains in synch (and the video will then play slightly jerky). If it's done by simply speeding up the video then it'll throw the audio out of synch. The question really should be, "Why are you doing this?"
Changing audio frame rate?
By architectofpain in forum AudioReplies: 22Last Post: 5th Apr 2013, 11:27 -
Changing DVD Frame rate
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 7Last Post: 28th Dec 2011, 20:58 -
Audio sync issue, Virtualdub, old video clips changing frame rate
By litmus in forum Video ConversionReplies: 1Last Post: 19th Sep 2011, 12:35 -
changing frame rate, making a better dvd picture
By motleycool in forum Newbie / General discussionsReplies: 3Last Post: 25th Aug 2007, 03:30 -
Frame rate conversion by changing frame count
By asmaa in forum Video ConversionReplies: 2Last Post: 1st Aug 2007, 11:15
