Hello.
I have a DVD which resolution is 720x576 PAL
I want it to be converted to AVI with the same output resolution, so I set in "Advanced settings" fixed width 720.
However AutoGK cuts height to 544
Is there any way to prevent this ?
I searched in Advanced Options (Ctrl-F9) but no luck.
Thanks in advance![]()
AVI support for rectangular pixels (DVD) is very poor, that is why many conversion apps default to square pixels, where 720x544 would give presumably the same aspect ratio (4:3). But perhaps you already knew that.
In my experience support for non-square pixels in AVI is very good now.
I don't use AutoGK but is there a way to force it to assume the source video is 5:4? That way it would would leave the frame size 720x576. Then, after encoding, you could use Mpeg4Modifier to change the pixel or display aspect ratio. -
In the Hidden Options set the aspect ratio as 'Original'. Just be warned that without also changing the PAR afterwards using MPEG4Modifier or adjusting your player's playback aspect ratio, your resulting AVI will play with the wrong aspect ratio.
Why would you want to resize unless your player has a problem with non-square pixels -- very rare with modern devices.
*sigh* Another issue - "force mono" missing in AutoGK.
By teapot in forum Newbie / General discussionsReplies: 7Last Post: 15th Apr 2013, 20:32 -
Visual Hub / DVD / Where is "force anamorphic" ?
By webstar in forum MacReplies: 2Last Post: 30th Jun 2010, 05:13 -
Creating "force-play" DVD chapters using a Mac?
By Cyrax9 in forum MacReplies: 10Last Post: 19th Jan 2010, 07:45 -
AutoGK question: Can I "Force IVTC" on "Hard-encoded NTSC&am
By BozQ in forum DVD RippingReplies: 11Last Post: 12th Jun 2009, 14:46 -
Decrypter "Brute Force" mode can damage the writer, or produce ba
By Bruxo in forum DVD & Blu-ray WritersReplies: 5Last Post: 2nd Dec 2007, 16:26
