  1. I have a Q6600 OC to 3.2 Ghz and a GTX275. I'm using MPC_HC with CCCP-2011-07-30 and CoreAVC 3.0
    If I enable CUDA, there's a noticeably longer lag time when seeking (using 1GB+ 1080p videos). If I'm at the 9:00 min mark and click to 15:00, it'll take ~2 seconds for the video frame to actually refresh to the new scene and start playing again. If I turn off CUDA or turn on DXVA, the lag time is on the order of milliseconds.
    Is this normal?
    Oct 2005
    666th portal
    cuda only uses the video card to play the video in the file, not do o.s. level file control. turn it off if you don't like the results.
  3. Try changing source filters.
