I DL's two similar .flv file from the Net not DMR etc
I had hoped to put them on my Pad/Pod and show them around.
I have ElGato turbo.264 and handbrake and Videora.
the first file ElGato did fine.
the second it claimed it could not recognize
they seem the same to me
of course Handbrake and Videora were not interested at all
here are the files:
One which worked:
File 1
General / Container Stream # 1
Total Video Streams for this File -> 1
Total Audio Streams for this File -> 1
Video Codecs Used -> On2 VP6
Audio Codecs Used -> MPEG-1 Audio layer 3
File Format -> Flash Video
Play Time -> 30mn 11s
Total File Size -> 368 MiB
Total Stream BitRate -> 1 706 Kbps
Video Stream # 1
Codec (Human Name) -> VP6
Frame Width -> 784 pixels
Frame Height -> 576 pixels
Frame Rate -> 25.000 fps
Total Frames -> 45279
Display Aspect Ratio -> 4/3
QF (like Gordian Knot) -> 0.133
Video Stream Length -> 30mn 11s 160ms
Video Stream BitRate -> 1 500 Kbps
Audio Stream # 1
Codec -> MPEG Audio
Codec Profile -> Joint stereo
Audio Stream Length -> 30mn 11s 160ms
Audio Stream BitRate -> 128 Kbps
Audio Stream BitRate Mode -> CBR
Number of Audio Channels -> 2
Sampling Rate -> 44.1 KHz
Bit Depth -> 16 bits
Audio Stream Delay -> 27ms
Two which did not:
File 2
Play Time -> 31mn 0s
Total File Size -> 376 MiB
Total Stream BitRate -> 1 693 Kbps
Video Stream # 1
Total Frames -> 46511
Video Stream Length -> 31mn 0s 440ms
Audio Stream # 1
Codec -> MPEG Audio
Audio Stream Length -> 31mn 0s 440ms
what can I do and what am I missing?
So many thanks!
MPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
QTPro, MPEG2 add on MPlayerX2
MPEG Streamclip
24 + 21" samsung flat panels
G4dual 2GB
AlchemyDVR card -
Forget the ElGato dongle for now. Try MPEG Streamclip. If that doesn't work, try QuickTime 7 Player Pro (assuming you bought the key).
Is the uncooperative file available for download anywhere? I can try it with my setup and upload the conversion if successful. -
Streamclip worked fine. forgot all about that program as I havent used it in a while.
odd though that ElGato saw the files differently, as to my eye the file info looks the same.
many thanks again!MPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
MPEG Streamclip
G4dual 2GB
AlchemyDVR card
which software works best for flv to dvd can i convert dvdor flv to divx
By rugrat23 in forum Video ConversionReplies: 2Last Post: 19th Jan 2011, 13:39 -
Problems with convertions
By kishidomatt in forum Newbie / General discussionsReplies: 1Last Post: 13th Aug 2010, 00:45 -
shoot-keep to ext disk-watch ! no convertions, is it so difficult?
By Phoebos in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 26th Jan 2010, 02:25 -
AVCHD(.mts-sony hdr sr5) convertions questions
By dragonstd in forum Video ConversionReplies: 14Last Post: 25th Mar 2008, 20:01 -
Subtitles, convertions and the correct adjustment
By harryharry in forum MacReplies: 2Last Post: 31st May 2007, 04:46
