  1. Hello Dear One's
    i want to know that which video cutter is best for all kind of media files ( including avi, mkv files )
    i have many mkv files from those i want to cut songs but i can't find a good cutter for this purpose
    tell me which Converter is best? please Recommend me
    Thank You!
    USA
    You could try AVIDemux. It's fairly versatile.
    But be aware that highly compressed formats like MKV (H.264 codec) can be very difficult to edit and make accurate cuts. That's due to the widely spaced keyframes. (I frames)
    If the keyframes are spaced ~300 frames apart, which is common on those type of codecs, you may not have much accuracy on your cuts. You need to cut on keyframes or you may have sync problems. Or you can re-encode if you need more accuracy. But then you will have some quality loss.
    EDIT: For a converter, depends on what formats you want to convert from and to.
  3. Thank you redwudz <3
    Dearie, mostly I'm having AVI & mkv files to have cut, but this software AVIDemux still not helped me it given error while i tried to cut a mkv, any other tool which you recommend please? (which surely cuts AVI & MKV)
