hi gys
i am new here
i want to rip dvd to
Format profile : High@L5.1
using handbrake or any nother software
can any body tell me
thaxs![]()
Results 1 to 9 of 9
not used as high@5.1 is 1920x1080 or higher. dvd is 720x480or576.
i have seen following atleast
Codec : AVC *=
=*Codec profile : High@L4.1 =*
*=Bit rate : 2138 Kbps *=
=*Width : 864 pixels =*
*=Height : 368 pixels *=
=*Display Aspect ratio : 2.35 =*
*=Frame rate : 25.000 fps
please tell how to encode in this atleast -
any h264 encoder. vidcoder, mediacoder, handbrake, etc... the main level is all that's needed for dvd, but you could set it as high as you want. bigger filesizes and not everything will be able to play it back.
hi and what is average bitrate to be kept when we want dvd rips with same quality as dvd
Actually, the process of 'ripping' is merely copying what's on the DVD (almost) exactly, minus the protection. So, by ripping you'll always have the exact quality as what's on the DVD.
What you're asking about doing is ripping and then converting the video(s) - or basically, upconverting, to some extent, I believe.If cameras add ten pounds, why would people want to eat them?
x264 AVC High@L5.1 to High@L4.1 conversion
By Pr0metheus in forum Video ConversionReplies: 16Last Post: 11th Oct 2013, 14:37 -
[Q] Convert MKV Format Profile from High@L5.0 to High@L3.1?
By xIntenso in forum Video ConversionReplies: 5Last Post: 26th Aug 2013, 21:46 -
What is the difference between x264 AVC High@L5.1 and High@L4.1?
By Bonie81 in forum Video ConversionReplies: 9Last Post: 26th Aug 2013, 19:40 -
Profile Format High@L5.1 Not supported by Sony S370 BDP - Help
By whALL in forum DVD & Blu-ray PlayersReplies: 1Last Post: 21st Jan 2012, 12:43 -
mkv avc profile change for ps3
By ckamc in forum Video ConversionReplies: 15Last Post: 16th Jan 2012, 10:24
