Hi there, I was wondering if a netbook solution (with an usb sound card) would be enough for recording task...
I don't talk about quality, I know that's depend on the pipeline of ambient, mic, soundcard ADC and so on...
I just was wondering if an Intel Atom cpu would be enough for running a recording software/editing.
You see.. I was thinking about a cheaper solution and probably that's the best choice. Other advantages would be netbooks are quite, and no need of sound proof panels around case...
I will probably go with a RODE/AKG mic + M-Audio Fast Track Pro (usb) + Netbook.
What do you think?
Results 1 to 1 of 1
Surround speaker home cinema advice
By aelfheah in forum Newbie / General discussionsReplies: 22Last Post: 20th Jan 2012, 06:56 -
Speaker wire to RCA? cable needed...
By flamy in forum AudioReplies: 12Last Post: 24th Dec 2010, 12:05 -
Choosing Hardware and Software Help Needed
By The OrangeLemon in forum Newbie / General discussionsReplies: 1Last Post: 17th Nov 2010, 17:05 -
Edited sound jumps from speaker to speaker
By len hend in forum AudioReplies: 3Last Post: 23rd Jul 2010, 05:49 -
hardware acceleration for 1080p material, is it needed or not?
By THX-UltraII in forum Newbie / General discussionsReplies: 3Last Post: 19th Aug 2008, 14:06
