I have video files with a .VOB extension.
These play fine in the VLC viewer software, but are not recognized when attempting to import to the VLMC editor.
So .... am looking for advice on converting VOB to another format that is loadable in VLMC editor, or .....
Maybe another free (or inexpensive) video editor.
I'm not looking to do fancy edits ... just simple grab interesting pieces from several videos and string them together with background audio.
Any thoughts ?
Thanks in advance folks,
Freddy Fredster
Appreciate your response aedipuss.
Before seeing your post, I was able to find another easy-to-use converter.
Converted file to MPG2 easily, which allowed VLMC to import my video.
However, I now find that I'm such a newbie at video editing that I'm having trouble using the VLMC software.
I've spent several hours looking for Help, Tutorials, Demos, etc ... found a little but nothing comprehensive.
I can view the video in the editor .. just not sure how to cut, splice, overdub sound, etc
Can anyone point me to a good source for learning VLMC features ?
Or ... maybe point me to another (better documented) simple and inexpensive editor ?
Thanks,
F'ster -
Freddy if I was you I wouldn't convert the vobs, I would use an editor that can handle vobs directly. With DVDShrink can edit/cut/join DVD vobs & make a new DVD structure. Or you can use an mpeg editor like what aedipuss suggested. MPEGVideoWizard would do everything you want (but is not free). You can demux your finished edited sequence, replace the audio, then remux. What format do you want at the end of the day? Do you want a DVD?
VLMC - video editor
By tin2tin in forum Latest Video NewsReplies: 39Last Post: 29th Jul 2011, 06:09 -
VOB merger/splitter/editor
By altavistasf in forum EditingReplies: 5Last Post: 17th Oct 2010, 21:16 -
Free VOB Editor
By acw in forum Newbie / General discussionsReplies: 2Last Post: 5th May 2009, 18:12 -
Need a native 64 bit editor for avchd files (maybe)
By BurnBabyBurn in forum EditingReplies: 0Last Post: 16th May 2008, 17:36 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 17:15
