Looking to transfer some video from camcorder to my iMac.
The camcorder is pretty old, working with a JVC GR-D395U miniDV.
I *think* I've found some cables but I'm not sure on the pin number.
Do I need a 9/4 pin cable?
The camera has a 4 pin port. Your computer would likely have a 6 pin or 4 pin port for FW400, or a 9 pin port for FW800. The smaller 4 pin ports are more common for laptops.
So use a 6/4, 4/4 or 9/4 pin cable, depending on your computer port.
Picture of a FireWire 9p - 4p cable:
...and do make sure you have connected the camcorder to power, as well.
good store on line to buy all your cables from
http://www.monoprice.com/products/subdepartment.asp?c_id=102&cp_id=10301
majority of camcorders are 4 pin(my Canon camera) and the one on my Gigabyte GA-MA78GPM-DS2H Motherboard is 6 PinLast edited by MJA; 7th Sep 2011 at 17:32.
Firewire to usb 2.0 cable
By zanos in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 1st Aug 2010, 13:28 -
firewire to usb 2 cable
By pavilion1250 in forum Video Streaming DownloadingReplies: 2Last Post: 15th Apr 2009, 22:01 -
firewire cable required
By rizvi in forum DVD & Blu-ray RecordersReplies: 1Last Post: 18th Mar 2009, 07:14 -
Ipod firewire cable?
By budz in forum Portable VideoReplies: 0Last Post: 27th Nov 2007, 21:22 -
Camcorder - Firewire to USB cable
By geek2330 in forum Newbie / General discussionsReplies: 11Last Post: 18th Jun 2007, 10:29
