Hello,
when I try to add a *.sup DVD subtitle to mkvmerge (GUI) it tells me that it wouldn't be a supported container format (HD-DVD sub).
Is there an easy way to convert the subtitles to a format that mkvmerge can deal with?
A similar easy to use DVD demuxer like PgcDemux with a compliant subtitle format would be great too.
Thank you.
Results 1 to 11 of 11
try subtitle edit to ocr them to a compatible format.
Unfortunately, Subtitle Edit says the subtitle file would be too large.
It's about 4MB. Is this normal? -
i've never seen that myself. try letting it get the subs directly from the dvd? if that doesn't work do a search for the movie name and subtitle. there are some sites you can download them from.
Convert the SUP file PGCDemux gives you to VobSubs (IDX/SUB) using SubtitleCreator.
can it go directly to srt which is what's needed, or do you need to then go from sub/idx to srt with subtitle edit?
If it only supports SRT subs, then my suggestion is useless, of course. I've never used MKVMerge. But often programs that don't support SUP files will support VobSubs. The advantage of using VobSubs, if possible, is that you get subs identical to those in the DVD, as far as colors, font, positioning, size etc. goes.
This "works" but unfortunately it takes forever (at least long) and the result is somehow messed up (subtitles don't fit anymore to the right frame etc. etc.).
I want to do a remux to save time.
It can't open the files, gives this error:
I'm starting to believe that the extracted *.sup files by PgcDemux are simply corrupted. I tested with two totally different DVDs and it didn't work.
Video and audio are demuxed fine though.
Seems like I need another tool to extract the subtitles (only).
Any suggestions?
I have used this program many times to convert BR sup files to srt. It will give the too large dialog if you try to drop the file into the program. When you load the program under the file drop down box there are about a half dozen import selections so my suggestion would be to try to find one that would take your subtitle without the too large error.
For BR sups the selection is import/OCR sup.
Tony -
He says they're from DVD.
He says they're from DVD, demuxed by PGCDemux.
If I've extracted SUP files from DVDs using PGCDemux once I've done it a thousand times. And none were corrupted. I don't even know why you suggest they are. Because MKVMerge doesn't support DVD SUP files (which are different from Blu-Ray SUP files)? You can test them by opening them to read in either SubtitleCreator or SUPViewer. You can even convert them to SRT automatically using DVDSubEdit (along with the IFO).
Adding Subtitles to DVD with PGCDemux, SubT WorkShop & Muxman - no subs??
By bahjan in forum SubtitleReplies: 19Last Post: 20th Apr 2012, 15:03 -
Demuxed Audio is longer than Demuxed Video, help!
By caesarhawy in forum EditingReplies: 3Last Post: 26th Apr 2010, 05:18 -
MKVMerge not showing subtitles
By darkdream4 in forum SubtitleReplies: 2Last Post: 6th Jan 2010, 17:40 -
Removing all subtitles using mkvmerge
By viperx116 in forum SubtitleReplies: 2Last Post: 29th Dec 2009, 14:24 -
Added subtitles too wide
By gnappa in forum SubtitleReplies: 12Last Post: 21st Apr 2008, 03:45
