I,ve been having some problem with movie only option using bd rebulider with to movies, Thor and xmen first class.
Every time i run bd rebulider movie only, I end up having the entire movie with directors comments and other bd extra. Is there any way I can strip out all the extra from movie only? I also tried using tsmuxer to strip movie only but I keep getting the same problem.
	You don't say what you're using to decrypt the discs. It may be that they aren't being decrypted properly. Alternatively, they may have complex java structure and/or PiP (picture-in-picture), or perhaps branching. (Neither of those movies have been released yet in the US.) Have you made certain your decrypter is up to date?
 You could try running AnyDVDHD or DVDFabPasskey and extract main movie directly from disc with Clown_BD, without ripping to hard drive first. I had to do this recently with the Harry Potter Deathly Hallows Part One disc. Nothing else worked. That disc is fiendishly complex and decryption was faulty using DVDFab.
 Anyway, you could try it. And welcome to the forum. Pull! Bang! Darn! Pull! Bang! Darn!
	I have tried to burn my movies onto a my PanasonicDMP-BD60,but when i load the disc i get this "No Recording Found". I used Cyberlink burning software, and use Panasonic blu-ray discs. This is the first time i have tried to burn things onto a blu-ray.
  M2TS, AVCHD, BLU RAY Playback Problem on Sony Blu Ray PlayersBy messi magician in forum Authoring (Blu-ray)Replies: 11Last Post: 15th Jan 2012, 19:25
  Wanna convert Blu Ray Movie to Play on Laptop/PC without a Blu Ray PLayer !By augustya in forum Blu-ray RippingReplies: 5Last Post: 13th Aug 2011, 04:35
  Whats the diffrence between AC3 Blu-ray movie and a x264 movie?By evdeneale in forum Newbie / General discussionsReplies: 1Last Post: 21st May 2011, 00:16
  how to rip a blu-ray movie to a blu-ray discBy TURBOLENCIA in forum Blu-ray RippingReplies: 1Last Post: 25th Nov 2010, 17:40
  convert non blu ray movie to blu ray disc???By dalmar6677 in forum Authoring (Blu-ray)Replies: 2Last Post: 31st Aug 2010, 19:51
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
