Hello I am just starting out and need some advice. I am wanting to take some of our families HI-8 video (s-video) and burn it to VCD or ??? I am looking at the Winnov Videum 1000 made for the Windows XP OS. What I need is what is the best software for doing what I intend to do. Best bang for the buck. Here is what I have in my PC.
AMD 1333
K7t266 Pro 2 mobo
512 ddr
40 gig ibm 7200rpm HD.
Acer 24/10/40 burner
Any help or advice would be helpful
k8spy,
I've just been pretty much using whats available here in the HOW TO section.
I capture the vdo first by using virtual dub as explained here:
http://www.vcdhelp.com/mjpeg.htm
Then i convert it to MPEG using TMPEG:
http://www.vcdhelp.com/tmpgenc.htm
And lastly i just use NERO to make the VCD.
Hope this helps...
Cheers.
Need advice
By Nator in forum ComputerReplies: 2Last Post: 29th Mar 2012, 11:06 -
New PC advice
By neworldman in forum ComputerReplies: 14Last Post: 19th Feb 2010, 10:17 -
Advice on a new audio/video system(I need advice and direction)
By hellfire45 in forum Newbie / General discussionsReplies: 1Last Post: 15th May 2008, 00:20 -
Looking For Advice. I'm hoping to get some advice about a DVD burner
By wtsinnc in forum DVD & Blu-ray WritersReplies: 5Last Post: 4th Dec 2007, 23:39 -
I need some advice
By CM World in forum MediaReplies: 1Last Post: 6th Aug 2007, 05:58
