Im trying to remux a tv series from flv format to M2TS Transport streams.
I am doing this to stream them from a pc to a media extender via windows media center.
The problem is some episodes have variable framerates.
In mediainfo it shows: Original framerate: 23.976 Average framerate: 25.066 (example), also minimum and maximum.
I can easily extract the audio and video with Yamb. I can also easily mux into m2ts with TSmuxer,
but I cannot manually input the framerate. TSmuxerGUI only has the basic framerate options, and I've never touched command.
Episodes with framerate 23.976 remux perfectly and look beautiful.
The others all have audio out of sync no matter what settings are used.
MKVmerge has a field for FPS and if I input the average framerate, I can create a MKV file
that works fine, however the video quality when played is rather poor.
Ive tried encoding the audio to the new framerate, though unsuccessfully.
Can TSmuxer, when used through command prompt, use a custom framerate for H264?
If so, could someone explain to a dummy how to type a script for this?
If not, is there another simple alternative?
Thanks for any advice.
Results 1 to 1 of 1
Strange AC3 mkv sync issues
By MarkyMarky in forum AudioReplies: 6Last Post: 6th Jan 2011, 09:40 -
Demuxed VOB into M2V and AC3 -- Sync issues
By jj_30 in forum ProgrammingReplies: 0Last Post: 16th Jul 2009, 13:38 -
Audio Sync issues under Vista 64 and H264/AC3 MKV files at 1080p
By tarrantm in forum Newbie / General discussionsReplies: 3Last Post: 6th Jan 2009, 22:56 -
H264/AC3 (MKV) to H264/AAC (MP4) ?
By jccca in forum Video ConversionReplies: 10Last Post: 13th Dec 2008, 20:06 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 11:24
