I've got a Pentium dual-cpu @1.73ghz with 2gb system ram + 4gb Readyboost ram.
What is the best software for cropping video on such a system?
I tried AVS Video Editor 5.1, but its 'Ken Burns' (zooming) effect was very awkward, as you couldn't click & drag to select your zoomed area -- it required you to select 'right middle' or 'bottom middle' etc.
Any other software that has a better zooming function that i could try?
I am planning on using Avidemux or Super to convert my source video into lossless format (eg. Huffyuv + PCM ) in order to make it as easy as possible for the editor to crop/zoom.
Then when I've prepared a bunch of zoomed clips, I'll join them all together. Surely that won't be too much of a task for my underpowered machine? Or maybe I'm far too optimistic?
You can do it, it may just be slow and take hours.
I am unclear - are you zooming video clips, or creating video clips by zooming stills ?
Zooming stills works because you usually have much more resolution in the photos that you need for video, which gives you room to move around withint he frame without actually having to resize the image. Zooming video rarely works unless you have HD source and are working at SD resolution and you keep the zooms modest. If your source is the same resolution as your output then you have to resize to zoom, and the results will blurry, pixelated video.
Regardless, try Vegas Movie Studio and the Track Motion effect. It will do what you want, within the bounds of physical reality.Read my blog here.
Thank you for your suggestion!
Yes i am talking about video-zooming, and I don't mind that the result might end up blurrier or pixelated -- it's more important to 'focus' in on the action (a Judo match).
low end quadro is 5 times faster than high end gaming card
By deadrats in forum ComputerReplies: 4Last Post: 7th Apr 2011, 16:42 -
Low profile capture card options
By GLE3 in forum Capturing and VCRReplies: 7Last Post: 30th Mar 2010, 18:59 -
What is wrong with this picture? Zoom? Overscan? Crop?
By Xenogear900 in forum Newbie / General discussionsReplies: 9Last Post: 9th Sep 2008, 17:35 -
Vegas Pan & Crop: Non squared zoom?
By stantheman1976 in forum EditingReplies: 1Last Post: 4th Dec 2007, 17:10 -
Low End Video Card w/ adapter vs. Low End DVD player
By enter8 in forum Media Center PC / MediaCentersReplies: 6Last Post: 20th Aug 2007, 16:45
