Below is the link to a video i made. It is a sample of some morphing software i am using. As you can see, it says "morphing" near the bottom, as the video is playing. Can someone recommend a virtualdub plugin, or other method of removing that text, so there is just the video playing? I would figure it would be like a de-logo type of plugin, but as long as it will remove it, i will try anything. I appreciate any help you could give me.
Thanks!
http://www.dropshots.com/sneezer#date/2011-09-05/17:13:41
	is this a "watermark" from trial morphing software?
 If so, can you just input a black lower border when making the video, then crop it out later ? (assuming the "logo" stays at the bottom) ?
	no. It is freeware software. It just has that nagging text there. The text just stays at the bottom, and scrolls across as it's morphing, hence the "morphing" part  I will try your suggestion. I will try your suggestion.
 Thank you!
  How do you place an image directly INSIDE a video clip?By Devilsadvocate in forum EditingReplies: 19Last Post: 27th Feb 2012, 12:27
  Streaming video from inside bird nest boxBy John T in forum Video Streaming DownloadingReplies: 1Last Post: 30th Apr 2011, 12:27
  How to embed a video in a Picture ??? example insideBy momo1984 in forum Newbie / General discussionsReplies: 2Last Post: 24th Mar 2011, 11:13
  Having trouble demuxing a dvd - seems to erase some of the video?By architectofpain in forum Authoring (DVD)Replies: 4Last Post: 28th Aug 2009, 13:36
  Authoring causes video to slow... (explained inside)By Liquid Drum Theater in forum Authoring (DVD)Replies: 13Last Post: 11th Sep 2007, 15:17
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
