Run a computer monitor off my HV40?I'm wondering if I can run a computer VGA type monitor off my camcorder or will I have to buy a wide screen 19" or so HDTV. Thing is I have a couple of extra 19" ViewSonic computer monitors but, they only have the VGA type input jacks. Is there an adapter jack or just no can do? I just want to be able to see what my camcorder is framing before I start shooting. It is a indoor fixed set. I don't need an expensive 7" on the camcorder type monitor for moving around a lot. The camcorder is fixed position for talking head shots.
the hv40 has multiple output possibilities.
1x HDMI A (Full Size)
1x FireWire
1x USB 2.0
1x Component Video (out)
1x Composite Video (out)
1x 1/8" (3.5mm) Stereo Mini
the hv30 came with composite and component cables iirc. don't know what the hv40 includes.--
Guess I worded my question wrong. HV40 has a lot of output options. That's great. I have computer VGA type monitors that I would like to output to (from the HV40). Can I or do I have to buy a new HDTV monitor?
if they have composite (yellow/red/white) or component y cb cr (green/blue/red) input. i can't look at the back of your monitors. otherwise hdmi is needed.
I would see three options:
- Free or cheapest...place a computer CPU (or laptop) with firewire input near your camera setup (since you say itīs indoors and somewhat fixed), conect yor cam and VGA monitor to it and check your video input from the capture program of your choice.
- Not that inexpensive...Buy a scan converter like these:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3685565&CatId=28
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1208335&CatId=1430
or search for an HDMI to VGA adapter (I couldnīt find any but didnīt look too hard)
- Most expensive...As suggested by you, get a new HDTV monitor/TV with the most inputs possible.
Time-lapse on HV40
By videobread in forum EditingReplies: 1Last Post: 25th Dec 2011, 15:26 -
canon hv40 test
By foofie131 in forum TestReplies: 1Last Post: 10th Apr 2011, 16:44 -
canon hv40
By foofie131 in forum Newbie / General discussionsReplies: 1Last Post: 23rd Mar 2011, 22:01 -
beginner - Canon HV40
By roboko in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 29th Jul 2010, 08:45 -
canon hv40 vs hv30/20
By minidv2dvd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 6th Feb 2009, 13:25
