Hi,
I recently acquired media player HD, so I'm in the process of ripping my DVD collection to MVK files. I'm using handbrake.. but the audio volume is terribly low..
I've searched and can only really find a suggestion of setting FFDshow to mixdown audio to 2.0.
Could somebody clarify how this is done in the FFD configuaration settings as I can't seem to find anything..
Are there either, other free conversion programs thatoffer volume boosting or an option to encode the audio to 2.0?
OR is there a free program that can re-encode the audio track to a higher volume or to 2.0 (whichever cures the issue)
Thanks!
	You can take advantage of FFDshow that way, assuming the converting program is using directshow
 to access the source files. I've done it may times in Virtualdub; open the source using the directshow input filter,
 and allow FFDshow's mixer to do it's magic, passing 2-channel PCM to Virtualdub where I can easily convert it mp3.
	Hey,
 No im re encoding the audio to either aac or mp3.. neither make any difference to the volume.
 I'd read that the ffd encoder had something to do with the speaker configuration for the desired output audio?
 Any suggestions?
	On the audio tab in handbrake, there is a slider labelled DRC - try moving it to the right (try between 2 and 3)
 and retry the encode.
 If you want to do the audio separately so you can mux it in yourself, download and install avidemux
 32 bit - http://avidemux.razorbyte.com.au/binaries/2.5/SVN/7428/avidemux_2.5_r7428_win32.exe
 64 bit - http://avidemux.razorbyte.com.au/binaries/2.5/SVN/7428/avidemux_2.5_r7428_win64.exe
 Open the source file in avidemux. At "audio" (on the left) set it to ac3(aften) or mp3(lame) depending on what you want.
 In "configure", set the bitrate.
 In "filters" set mixer to stereo and select "dynamic range compression" (OK out)
 At the top, audio/save/save your file (eg myfile.mp3)
 The processing in AVIdemux is quite slow, but the result is good.
  HandBrake Low FPSBy Guess Who in forum Blu-ray RippingReplies: 6Last Post: 17th Oct 2011, 12:27
  tsMuxeR converts MKV but I have no sound.By pixiesoft in forum Authoring (Blu-ray)Replies: 4Last Post: 6th Apr 2010, 22:33
  Low audio volumeBy Daz_uk in forum Capturing and VCRReplies: 0Last Post: 29th Jan 2010, 14:34
  mac program that converts mkv?By furida in forum MacReplies: 4Last Post: 17th Aug 2009, 17:59
  Youtube: why the low volume?By kevs in forum MacReplies: 3Last Post: 23rd Nov 2008, 07:07
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
