Hi guyz.
There is something I am trying to figure out for long time. I have a movie in AVI format and subtitles in SRT. I wanna show movie to kids but there are some scenes I want to cut out of movie. All I want that when I trim the video, subtitles also get trimmed and get synced with the video. Is there any way or software or something.
I think you can delete the offending lines from the .srt file without it affecting the sync.
You can create a blank bmp logo the same resolution as the video and use VirtualDub and the Donald Graft Logo Filter 1.7 to cover the frames that offend.
You either insert the filter multiple times with the start frame and the duration (number of frames to cover with the logo) or use the 'Blend' feature to select the start and end frames for each section you want to hide.
It can probably be done using AviSynth, but it would be easier in VirtualDub as you can see the results immediately. -
This is only a suggestion, as there are much more knowledgeable people on here but i would embed (hard code) the subtitles into the avi and then make my cuts. That way you will avoid the high probability of sync issues. Try avidemux. Again, this is just my opinion.
Help with converting video / adding subtitles - subtitles are off from audi
By kurohoshi in forum Video ConversionReplies: 0Last Post: 27th Dec 2010, 15:53 -
Issue trimming video and removing ads
By calande in forum EditingReplies: 14Last Post: 30th Jun 2010, 15:56 -
Trimming the audio to go along with the video cuts in avisynth?
By mt123 in forum Newbie / General discussionsReplies: 0Last Post: 10th Jan 2010, 03:23 -
Windows Movie Maker. Blank video when splitting, trimming video clips
By rlarden in forum EditingReplies: 2Last Post: 3rd Jul 2009, 06:23 -
Lossless Video Clip Trimming
By azvenigo in forum Newbie / General discussionsReplies: 0Last Post: 9th Mar 2009, 23:01
