    Jul 2006
    What's suitable for and will fit my HP Pavilion Elite HPE-510t PC?
    I still capture from mini dv tape from a Canon XH-A1.
    HP specs describes the part as a:
    "1394 PCI express x 1 expansion card"
    What does the x 1 stand for?
    Please explain. Any enlightment is appreciated.
    Thanks in advance.
    Oct 2005
    666th portal
    the speed and/or size of the pci-e slot. video cards are usually 16x, 2 video card normally each operate at 8x, usb 3.0 cards 4x, pretty much everything else is 1x
    Jul 2006
    Thanks for joining the discussion.
    If I may ask, do you have any specific recommendations?
    Do I need a low profile card and/or one with a TI chipset?
    I had a friend of mine open it up some time back to install a hard drive and some memory. There looked to be very little room inside.
    How do I know one way or the other? trial and error?
    Start with the low profile card?
