I bought a new PC for editing several months ago which does not have a firewire card.
Wanted a reliable, reasonably priced card.
Any reccomendations?
I still capture from mini dv tape.
You do not need a PCI-e card for firewire unless you don't have a free PCI slot, or have something that can use firewire 800, or need more than 3 ports. A PCI card will be enough and will cost less if none of the above applies to you.
[Edit] I have a firewire port on my motherboard, so I haven't purchased an add-on card. This inexpensive PCI card seems to be pretty good and is popular with customers at Newegg http://www.newegg.com/Product/Product.aspx?Item=N82E16815265002Last edited by usually_quiet; 4th Sep 2011 at 22:30.
I have a HP Pavilion Elite model HPE-510t PC.
The manufacturers product specs calls for a "1394 PCI Express x 1 expansion card."
What does the " x 1" mean?
Thanks -
Unfortunately I'm made to understand that I do not have one built in on my MOBO.
I bought a configuration to order system. -
HP built this machine cheap and ports are scarce.
Only had a couple built in. -
If nobody comes up with something better, this one looked like a good choice for use with a camera. It is a small card that comes with both a full height bracket and a low profile bracket. http://www.newegg.com/Product/Product.aspx?Item=N82E16815166018
Thanks, that card looks to be as good as any.
May order it tommorow and hope it works! -
Update!
I just ordered one.
May not get it until early next week due to the holiday weekend.
Need to buy a suitable PCI X firewire card for my newish PC ASAP
By Canon GL-2 Guy in forum ComputerReplies: 2Last Post: 5th Sep 2011, 00:08 -
Good Firewire PCI card for Capturing HDTV?
By superdud1400 in forum Capturing and VCRReplies: 1Last Post: 12th Jun 2008, 06:11 -
I need a good FireWire PCI card for capturing video.
By mob in forum Capturing and VCRReplies: 11Last Post: 1st Apr 2008, 02:19 -
Canopus ADVC-100 and PCI Firewire card
By spiderbaby in forum Capturing and VCRReplies: 12Last Post: 5th Mar 2008, 09:39 -
PCI/PCI Express 1x usb 2.0 card with 2 internal usb inputs
By SIRCOOKS in forum ComputerReplies: 0Last Post: 24th Jun 2007, 12:58
