I have been searching all over Google for a conversion tutorial to convert stereo MP3 to stereo AC3 music 2-channel format. Not a video format. I have music that are in .mp3. They will play on my iPhone in MP3 format, but I rather use the proper AC3 format. Are there any tutorials?
Also, are there tutorials for convert FLAC to AC3?
If possible, could BeSweet do the work, BeLite? I mean the GUI part?
Results 1 to 11 of 11
BeSweet has the ability, but its AC3 output has been criticised.
dBPowerAmp Music Converter can do it all, in batches.
Version 10 is still freeware and can handle all the formats.
AC3 is really only used for videos though. Why do you want to use it?
If it is AAC you want, dBpowerAMP can do that.
Get the codecs for the free version here: http://www.dbpoweramp.com/legacy/codec-central-legacy.htmLast edited by AlanHK; 4th Sep 2011 at 10:26.
See http://www.dbpoweramp.com/legacy/codec-central-mp4.htm
It says it needs Nero Digital Audio to encode to AAC.
Which you can get here: http://www.dbpoweramp.com/codec-central-m4a.htm
(I haven't done this myself, I used dBpowerAMP for FLAC, AC3 and MP3 conversions.)
You might find other tools here: https://www.videohelp.com/tools?toolsearch=AAC
Perhaps fre:ac might be worth a try.Last edited by AlanHK; 4th Sep 2011 at 10:40.
I tried dBPowerAmp first with both codecs installed. I didn't see a drop down list for the AAC. I'm lost. I didn't know which one to download, so I downloaded them both.
I just got Lame XP, and Nero AAC. I installed Lame XP, and I extracted the Nero AAC to a folder on my desktop. I am not too sure on how the command line works.
Which method should I use between both apps? How do I use them? -
If you have an iPhone then you must have iTunes on your PC - you can convert to aac within iTunes
https://support.apple.com/kb/ht1550SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851
How to Convert 2 channel stereo wave into DD5.1 AC3 448 / AC 640
By Bonie81 in forum User guidesReplies: 36Last Post: 2nd Feb 2018, 12:42 -
Preference for MP3 Joint Stereo Vs. Stereo ?
By davexnet in forum AudioReplies: 7Last Post: 27th Oct 2011, 11:49 -
Does anyone know how to convert joint stereo audio back to stereo?
By robrosen in forum AudioReplies: 1Last Post: 2nd Aug 2009, 22:24 -
Stereo, Joint Stereo or Dual Channel for Audio input type?
By c627627 in forum Capturing and VCRReplies: 1Last Post: 23rd Mar 2009, 09:33 -
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 11:23
