Results 31 to 34 of 34
Depends on your machine and source.
Speed of encoding is in fps.
I get about 18 fps usually, but can be much slower if the script is complex or the source is very high res.
I do 2-passes with HCEnc, so that doubles the time.
So one hour, two passes, takes me about 3 hours.
A new PC would probably be at least twice as fast.
Audio encoding via Aften takes only a minute or two.Last edited by AlanHK; 25th Sep 2011 at 03:55.
Yes, it depends on the speed of your computer, what software you're using, what settings you are using, the properties of the source, and any filtering you may be doing.
With my Core i5 2500K, encoding standard definition video with HcGUI at its "best" setting, no filtering, 2-pass encoding, it takes about 11 minutes to encode an hour of video. TMPGEnc Plus with motion search precision set at "Normal" takes about 16 minutes.
How to add selectable audio to a video without quality loss
By m.eshi in forum EditingReplies: 2Last Post: 27th Aug 2011, 09:09 -
editing mpg2 to dvd without quality loss
By dailM in forum EditingReplies: 2Last Post: 8th Aug 2009, 01:35 -
How to add Watermark to VCD MPEG1 without Quality Loss?
By shebi in forum Authoring (VCD/SVCD)Replies: 3Last Post: 15th Apr 2009, 13:13 -
Loss of quality with MPG2 format
By KayAt in forum Newbie / General discussionsReplies: 4Last Post: 23rd Mar 2009, 14:58 -
can I crop a m2v file without loss?
By cleantone in forum MacReplies: 7Last Post: 28th Aug 2008, 08:31
