Hi, can you help me with this? Is a file recorded using SopCast and every-time I try to convert it to a different format using Freemake Video Converter or any other conversion software it goes in crash. Thanks.
MediaInfo:
Code:General ID : 40070 (0x9C86) Complete name : C:\Users\Khalu\Desktop\yuiop.mpg Format : MPEG-TS File size : 199 MiB Duration : 35mn 54s Overall bit rate : 775 Kbps Video ID : 69 (0x45) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.0 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : 27 Duration : 35mn 51s Bit rate : 640 Kbps Nominal bit rate : 600 Kbps Width : 446 pixels Height : 450 pixels Display aspect ratio : 1.412 Frame rate : 25.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.128 Stream size : 164 MiB (82%) Writing library : x264 core 115 r2013 6fce39a Encoding settings : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x3:0x1 / me=umh / subme=2 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=10 / rc=cbr / mbtree=1 / bitrate=600 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / vbv_maxrate=600 / vbv_bufsize=6000 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00 Audio ID : 68 (0x44) Menu ID : 1 (0x1) Format : MPEG Audio Format version : Version 1 Format profile : Layer 3 Mode : Joint stereo Mode extension : MS Stereo Codec ID : 3 Duration : 35mn 54s Bit rate mode : Constant Bit rate : 96.0 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Compression mode : Lossy Delay relative to video : -57ms Stream size : 24.7 MiB (12%) Language : English
It plays well in VLC, KMplayer, PotPlayer - in Windows Media Player 12 but with hiccups. The only workaround I found is to play it and at the same time to record it using PotPlayer, to a different format (MKV, AVI , etc..)
Sounds like the file itself is corrupted - not enough to stop a robust player, but enough to stop it being easily re-encoded.
If VLC plays it then you could try the built in transcoder : http://wiki.videolan.org/TranscodeRead my blog here.
vob file has wrong length?
By Brainbanana in forum Video ConversionReplies: 16Last Post: 1st Mar 2012, 15:52 -
What is wrong with AVI file?
By vertical in forum Newbie / General discussionsReplies: 8Last Post: 2nd Feb 2009, 00:51 -
Vob File Length seems all wrong
By AlexHaden in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2008, 20:34 -
Why is this wmv file the wrong size?
By abisti in forum Newbie / General discussionsReplies: 8Last Post: 5th Feb 2008, 19:14 -
Wrong file sizes in Nero
By jhan in forum Authoring (VCD/SVCD)Replies: 5Last Post: 7th May 2007, 08:27
