I have an avi file about one minute long, and 20M in size. In order to e-mail it, I need to get it under 10M. Suggestions?
Results 1 to 11 of 11
filesize = bitrate x running time
so adjust the bitrate
you might use the same type compression or different type compression depending on what the AVI file uses
IMO a better option is to upload the 20MB file and use a free hosting site instead of email and provide the download link in the email , e.g. mediafire.com, dropbox.com, sendspace.com , many others -
Thanks for the list. That could do it.
When I was operating with Vegas 6.0, I'd do a render and somehow select something called like tiny or small whatever. I don't see any choices remotely like that. If I select video type of Video for Windows, then template choices are like NTSC DV, HD... It has practically no meaning to me. -
http://www.kiva.org/about -
I used AVC and Internet 4:3 SD 30p. I guess 30p is pixels? Size remained the same.
BTW, what "penalty" do I incur for using mediafire.com? They distribute ads to my e-mail? They show some notices on the site indicating they have praise from PC magazine, USA Today, CNET, etc.
30p is the frame rate. 30 frames per second, and "p" is for progressive
It's the same size because you used the same bitrate
Filesize = bitrate x running time
Since the running time is the same , the only variable is the bitrate
If you 1/2 the bitrate the filesize will be exactly 1/2 . But you have to use total bitrate (audio + video)
If you don' t know what the bitrate of the audio & video are in the orignal file, use mediainfo
You should also check the other characteristics like dimensions and frame rate. You might be running into some problems if you use the wrong project settings or encoding settings
If you mean "spam" to your email account, they don't. Also you don't have to submit your email account. You only have to use it if you sign up for an account, but you don't even need to sign up to use itBTW, what "penalty" do I incur for using mediafire.com? They distribute ads to my e-mail? They show some notices on the site indicating they have praise from PC magazine, USA Today, CNET, etc.
The only "ads" are the ones that occur when you open up the webpage download link, and when you are first uploading the file. Those are all in the web browser, not e-mail -
Thanks very much.
I uploaded the file, but I have no idea what to do next. There's stuff on the left that perhaps I need to use to identify where others can find the upload. "More Actions", etc. Maybe Help Resources. Description? -
Exactly . There should be an URL upload link to share. That is the webpage address that the recipient goes to download the video
They copy that address in their webbrowser and it will provide a link to download the video
You would share that address with whomever. You could place that link in your email correspondence to recipents, your own blog , your own webpage, message boards, etc...
The bandwidth is free, but the "cost" is the annoying advertisements on the webpage. If you use firefox and adblock it gets most of them
I think dropbox allows "direct linking". So you just right click and save (you don't have to go through a webpage first to get the actual download link) -
So am I finished? How do I find the link to the file now on their site? I use FF. Win7. I right-clicked on the file folder and got:
http://www.mediafire.com/myfiles.php. That doesn't usable. Clicking on the My Files folder reveals nothing. Dragging the avi file to My Files doesn't get me anywhere. Ah, passing over the the file name gives three pulldown menus (actions, downloads and share). Share has a link and link with file name. Copied it. Put in an e-mail to myself. Used the link. The web page opened, and asked if wanted to download. I just played it in Win Media Player. Very good.
I had hoped the avi would just plain gone to download. However, I guess they want to see the plentiful ads on their web page. I guess that's the "penalty".
Thanks very much. -
Yes that's the penalty for "free" bandwidth . The advertisements are how they pay for it
As I said in the post above, some sites allow direct linking. That would be you just right click and "save as" without even going to the webpage
Some paid accounts with some file host services enable more function as well, like direct linking, higher bandwidth, larger filesizes limits
There's plenty of "free" ones, I just listed a few popular ones
It's a "faux pas" to send large attachments (such as video) in email , because it clogs up email POP servers - the recipients that you send the video to will get a reduction in their email service. email servers are usually low bandwidth. This is a big reason you want to use this method to transfer instead of email
Reducing video file size
By black5 in forum Newbie / General discussionsReplies: 2Last Post: 15th Jul 2010, 18:09 -
Reducing the file size of digital pictures
By hardy in forum Off topicReplies: 25Last Post: 10th Mar 2010, 08:59 -
Limitingand reducing out file size
By TJF in forum Video ConversionReplies: 6Last Post: 7th Feb 2010, 10:25 -
reducing video file size
By srckaimal in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jan 2008, 21:51 -
Reducing mpg file size
By sknox in forum MacReplies: 2Last Post: 3rd Jul 2007, 05:41
