Hi,
I capture video with a component cable and a capture card in 720p. Is it a good idea to use a 10m (30ft) from my set-top box to my pc? Now I use a 3m cable and there aren't any visible artifacts. The reasen I want to use a longer cable is I always have to change the place of the set-top box when I want to capture video due to the short length of the cable. So, my question is, will I have loss of quality (I know I always have loss of quality, but I mean 'visible') using a 10m (Profigold?) component cable?
Thanks in advance
Good quality component cables up to 50' here, no problems ... cheap cables always cause issues
Ever thought of making it yourself? I have made several good quality cables cheaply. For component, take 3 same length of good quality 75 Ohm double shielded, solid core coax videocable and terminate with 75 Ohm HF shielded connectors and you're set.
Ennio -
Most pros do make their own cables. But it depends on what you mean by "quality" cable. The goods you buy in big box stores like Best Buy or sources like Radio Shack, hardware stores, etc., are unknown entities that rarely turn out to be "quality" stuff. A pro would get something like a 400-foot spool of Belden 1695, plus Centrex or Canare connectors and the crimping tools to make the connections. Home-made connectors are usually cheap tin stuff with poor soldered connections (pros don't use solder, they use crimping tools with solderless plugs made for this purpose). Factory-made heat-molded or crimped connections will outperform awful stuff like Monster Cable soldered joints any time. Pro crimping tools themselves will cost $200 USD or more. The OP mentioned Profigold wire. Everything I've seen and heard about them indicates it is a generally good line of products (I tried their HDMI, which made the HDMI sold in the U.S. look pretty anemic).
Can the mini HDMI or component cable be converted to AV?
By coody in forum DVD & Blu-ray RecordersReplies: 2Last Post: 7th Aug 2010, 07:14 -
Component cable
By alintatoc in forum Off topicReplies: 3Last Post: 23rd Jan 2010, 09:20 -
RGBHV, VGA, component cable confusion
By Asterra in forum Newbie / General discussionsReplies: 3Last Post: 9th Aug 2009, 19:58 -
DVI/Component cable
By ajcstr in forum DVB / IPTVReplies: 9Last Post: 16th Oct 2008, 05:25 -
VGA Cable Length?
By stim141 in forum DVB / IPTVReplies: 11Last Post: 19th May 2007, 03:59
