  1. Hello people
    I'm new to this software, when i open it says updates are available, it updates all but there left 4 files which are not getting updated, can any one please provide me a fully updated archive pack of MeGUI?
    and a little guidness to use this software
    thanks a lot!
    ___
    n please recommend me a converter which converts bigger files into small size without quality loss <3
    Did you download latest 2050 release? https://www.videohelp.com/download/MeGUI_2050_x86.zip
  3. yes i did but same problem presisting
    Jun 2004
    California,United States
    My experience with Megui has been that it is best to download a version and immediately check the box that stops it from downloading updated components. If I didn't, sooner or later it would download something new that was incompatable with the rest of it's components and it would no longer work or at least not work correctly.
    Tony
