OK guys, here's my situation:
I have game footage that I captured using Xfire, with their own XFR1 codec. However my problem is that I am wanting to edit my footage using my OS X Lion laptop. As Xfire still have no Mac support I can safely assume they won't have their codec working on Mac either, which leaves me with a problerm. Because it is the codec at fault here, I am curious as to how I can re-encode me video footage into a format that Premiere Pro CS4 for Mac can understand and import.
More information on the codec can be found here: http://wiki.xfire.com/index.php/Xfire_codec
So, what software can I use to re-encode it and convert it into a file format my video editing software can work with? What encoder would be best to use for Prem Pro CS4 Mac? Editing on the PC is out of the question... the best I have on that is Windows Live Movie Maker...
Daniel
I found nothing for OSX, but did find something for your Windows PC that may work. According to this link, http://iradar.blogspot.com/2009/06/how-to-play-andor-edit-xfire-videos.html Virtualdub (free, PC only) can import, edit, and convert XFR1 video in an .avi container.
The amount of freeware on Mac when compared to PC is mindbogglingly it is the main reason i still use Windows based PC or Linux. But if i were in a situation where i was using a Mac (Intel based) I would look into installing dual booting with XP or Win 7 or at a minimum a variant of Linux this would open your world to a myriad of software options that perform as well if not better than commercial software.
Murphy's law taught me everything I know. -
I know that as a Mac user you're not going to want to hear this, but as dragonkeeper pointed out, the sad truth is that on Mac you've got maybe 1 or 2 programs to do anything and if you don't like them, well, you're out of luck. I make my living supporting Linux and Unix computers and I'm not a fan of Windows, but that's where the software is.
Unless you are a hardcore gamer who is going to play Windows games on your Mac, an alternative that I prefer to dual booting is running VMware Fusion to get Windows running under OS X. Fusion is not freeware, but as it lets you run Windows under OS X (you are running Windows in a virtual machine while OS X itself is still running) you can just start and stop Windows as you wish with no need to reboot. -
Isn't the free VMWare Player available for OSX? VirtualBox is available for OSX, and free.
http://www.virtualbox.org/wiki/Downloads
Of course, you'll need a Windows license to run Windows. If you only need it temporarily you run Windows 7 for a month without a license. -
Because xfire is not open source, you need access to a PC with xfire installed
You can use avisynth to frameserve into ffmpeg to encode to MOV (something like animation codec, or png in MOV). These files will work on a Mac, even other programs like FCP.
AVI container is generally not supported on a Mac. You need it to be MOV wrapped -
According to this:
http://webcache.googleusercontent.com/search?q=cache:vl67nocJOpMJ:wiki.xfire.com/wiki/...ient=firefox-a
XFR1 is based on HuffYUV. You might be able to change the fourcc to one of the HuffYUV fourccs and use HuffYUV to decode it -- HFYU, FFVH. Depending on how much they changed the encoder.
Need advice for free antivirus+free firewall combo
By alegator in forum ComputerReplies: 16Last Post: 6th Jul 2016, 18:21 -
Two questions: Best free video converter & Best free muxing tool?
By milOtis in forum Video ConversionReplies: 7Last Post: 9th Jul 2011, 18:40 -
720p encode 700mb and 720p encode 1.5gb or over 3gb
By ali2k1 in forum Newbie / General discussionsReplies: 7Last Post: 26th Aug 2010, 14:09 -
Klipsch CS-500, need to make region free / code free / zone free
By Trialsman in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Nov 2008, 14:16
