Should I download I-tunes 10.4.1 onto my older Mac.
I am still running leaopard with non-Intel processor in my Mac G4. The online software updates are offering an update for I-tunes 10.4 which currently works fine on the Leopard OS. The update screen says that 10.4 is designed for the Lion OS and this update to 10.4.1 has some fixes. Will downloading it onto my older system create any problems, since I will never have Lion, at least on this computer because it is too old for that OS.
Do you think it's necessary? If you're not experiencing any problems with your existing version of iTunes, or don't have any new hardware which might require additional (read: new) support, like one of the newer iPhone/Pad/etc. models, it's probably not necessary to update.
I don't know if they'd consider it necessary to update in order to use the iTunes Music Store/App Store, though, however. Or whether or not they've implemented any critical security fixes which absolutely require an update. But if you don't use iTunes for the iTMS/App Store, it shouldn't matter.
Given that it's a point update, though (10.4 > 10.4.1), it probably won't be an issue.If cameras add ten pounds, why would people want to eat them? -
See if any of these are an issue with version you are currently using.Originally Posted by macupdate.com
However, in my experience, Software Update is smart enough to filter updates that apply to the hardware it is running on. It should skip updates that require different hardware or a different OS version.Last edited by Case; 3rd Sep 2011 at 03:15.
CD ripping (not vids, but tunes)...
By cwb in forum DVD RippingReplies: 13Last Post: 9th Sep 2011, 09:46 -
I-Tunes crashes every time I try to play something :(
By Akhet in forum ComputerReplies: 4Last Post: 8th Dec 2009, 18:59 -
AVI to I Tunes
By cobraper in forum MacReplies: 9Last Post: 3rd Aug 2008, 16:41 -
How to copy a CD w/tons of mp3 tunes to another CD??
By rbatty11 in forum AudioReplies: 6Last Post: 19th Jun 2007, 20:30
