Well, i got a bunch of MP4 (x.264/acc) videos of like 2-30 min duration each, all durations vary...
So, i now decided to demux the audio tracks from these MP4 vids and mux them with my friends songs instead. So i'll have songs converted to AAC, but shit, each song takes its duration that doesn't match with the video durations....
Is there some way or tool to mux MP4 with AAC audio which would cut the audio stream off when video stream ends? Most likely it's not an easy to understand, what i wrote, heh...
Imagine, i have a song of 5 min and a video of 3 min. If i mux the MP4 this way, i'll get MP4 with video of 3 min duration, and then when video ends it will play another 2 minutes of audio (without video)...
How can i automate the work to pick video file and audio file to mux them into 3 min MP4, without the need of loading the audio track into editor to crop it to 3 minutes manually for each video clip?
Also, is there a tool to batch mux a lot of MP4s so i won't end up spending a lot of time by doing hundred of videos by hands?
Thanks in advance
OK, i have found a way to batch remove audio stream and add new one by using .bat file with a command line for Mp4Box:
Question:Code:for %%a in (*.mp4) do "C:\Path\to\Your\Copy\Of\MP4Box.exe" -add "%%a:fps=23.976043" -add "%%~na.aac" -rem "2" "C:\Your\Output\Folder\%%~na.mp4"
what to do to match audio length to video length? -
I could do this job using FFmpeg.
With a video named "video.mp4".
And a new (longer) soundtrack named "soundtrack.m4a".
Remove the old soundtrack from the video.
Like this:-
Then add new soundtrack using "-shortest".Code:ffmpeg -i video.mp4 -vcodec copy -an silent_video.mp4
Like this:-
But maybe somebody else knows a quicker way...Code:ffmpeg -i silent_video.mp4 -i soundtrack.m4a -shortest -vcodec copy -acodec copy new_video.mp4
How to demux .avi file with multiple audio tracks?
By junglemike in forum AudioReplies: 8Last Post: 26th Oct 2012, 19:05 -
Easy way to extract (demux) audio tracks from Blu-ray folder?
By ricsee in forum Newbie / General discussionsReplies: 2Last Post: 11th May 2011, 12:12 -
All-in-one Batch demux FLV -> mux mp4?
By gaikokujinkyofusho in forum Video ConversionReplies: 2Last Post: 20th Jan 2011, 00:34 -
Can't Mux audio & video streams to MP4 without a problem
By spycam in forum Newbie / General discussionsReplies: 3Last Post: 10th Nov 2010, 17:49 -
Demux & Mux
By homantam in forum Newbie / General discussionsReplies: 1Last Post: 1st Sep 2007, 09:51
