Hello,
Here I just made a fresh installation of windows 7 x64, I installed avisynth
(all default - x86 v2.5.8 + x64 *.dll date 04-16-2010 in the directory
c:\windows\system32 and run the bat file) and updated MeGUI x64.
In a simple encoding Xvid (without audio) this plant: x (it works in x264)
Here is the log of MeGUI:
I have yet properly installed avisynth (all default)[Error] Log for job3 (video, VTS_01_1.avs -> )
-[Information] [02/09/2011 13:24:50] Started handling job
-[Information] [02/09/2011 13:24:50] Preprocessing
-[Information] [02/09/2011 13:24:50] Avisynth input script
--[NoImage] LoadPlugin("E:\Utilitaires\Megui_x64\tools\dgindex\DGDecode.dll")
--[NoImage] DGDecode_mpeg2source("E:\VTS_01_1.d2v", info=3)
--[NoImage] LoadPlugin("E:\Utilitaires\Megui_x64\tools\avisynt h_plugin\ColorMatrix.dll")
--[NoImage] ColorMatrix(hints=true, threads=0)
--[NoImage] #deinterlace
--[NoImage] crop( 2, 2, -2, -2)
--[NoImage] LanczosResize(720,400) # Lanczos (Sharp)
--[NoImage] #denoise
-[Information] [02/09/2011 13:24:50] Job commandline: "E:\Utilitaires\Megui_x64\tools\xvid_encraw\xvid_e ncraw.exe" -i "E:\VTS_01_1.avs" -pass1 "E:\VTS_01_1.stats" -bitrate 2000 -kboost 100 -ostrength 10 -oimprove 10 -odegrade 10 -chigh 30 -clow 15 -vbvsize 3145728 -vbvmax 4854000 -vbvpeak 2359296 -turbo -max_key_interval 250 -vhqmode 4 -lumimasking -imin 1 -pmin 1 -max_bframes 1 -bvhq -bquant_ratio 162 -bquant_offset 0 -bmin 1 -par 1 -threads 1
-[Information] [02/09/2011 13:24:50] Encoding started
-[Error] [02/09/2011 13:24:51] An error occurred: xvid [error]: Avisynth open failure:
-[Error] [02/09/2011 13:24:51] Process exits with error code: -1
-[Information] [02/09/2011 13:24:51] Standard output stream: xvid_encraw - raw mpeg4 bitstream encoder written by Christoph Lampert 2002-2003
-[Information] [02/09/2011 13:24:51] Standard error stream
--[NoImage] Trying to retrieve width and height from input header
--[NoImage] xvid [info]: Avisynth detected
--[NoImage] LoadPlugin: unable to load "E:\Utilitaires\Megui_x64\tools\dgindex\DGDecode.d ll"
--[NoImage] (E:\VTS_01_1.avs, line 1)
-[Information] [02/09/2011 13:24:51] Job completed
what is the problem, any ideas?
thank you
Results 1 to 1 of 1
Megui/Xvid: Process exits with error code: -1073741819
By BlueBlack in forum Video ConversionReplies: 1Last Post: 26th Jan 2012, 14:22 -
Megui with xvid 1.3.1???
By Mildragon in forum Video ConversionReplies: 8Last Post: 11th Nov 2011, 04:52 -
MEGUI MP4 to AVI XviD Error
By DruidCtba in forum Video ConversionReplies: 22Last Post: 6th Nov 2009, 14:35 -
Help! VirtualDub video/audio out of sync when enconding MPEG2 to XVID
By kbal in forum Video ConversionReplies: 6Last Post: 19th Dec 2007, 15:05 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41
