I noticed in Excel 2007, when you create an auto filter, you can select (check mark) certain data and it will return that information. Data--> Filter --> Autofilter
In Excel 2003, I notice the auto filter, you cannot select selected information. You can only select one data or do a custom. How come you cannot select multiple data points?
Sure you can. It just won't do anything. They wrote it that way. Did you expect 2003 to be more advanced than 2007?
something as simple as checking multiple data points to filter on was missing on 03.
I can do a custom filter, but with that, it only allows me to select two queries.
Let's say I have a group of 10 names. I want to filter, to return 5 names = jack, joe, john, james, jill
On the custom, I can set it to "equal" jack OR "equal" joe....but then thats it. It won't let me add 3 more custom entries.
Can anyone help? -
Re-run the query multiple times (once for "jack", once for "joe", etc), or separate them out to multple columns, or just upgrade to '07. That is one of the few real improvements...
edit: or create an additional column that contains the composites you want ("J's")
Help with an IF/THEN formula in EXCEL
By Rudyard in forum ComputerReplies: 4Last Post: 13th Sep 2011, 01:53 -
Sharepoint excel services
By jyeh74 in forum ComputerReplies: 0Last Post: 13th Jan 2010, 16:00 -
Excel help!
By alintatoc in forum ComputerReplies: 11Last Post: 6th Dec 2009, 20:42 -
How to activate macro's in Excel 2007 with a spreadsheet from Excel 97
By blinky88 in forum ComputerReplies: 3Last Post: 11th Feb 2009, 11:21 -
rounding up or down in EXCEL
By jyeh74 in forum ComputerReplies: 7Last Post: 19th Nov 2007, 02:32
