hi there...
i have a capture card and have been successfuling capturing dvd's for the past few months and obtaining a reasonable vdo image quality. i'm thinking now of getting a dvd player for my computer instead of hooking up an external dvd player to capture video.
my dilema is that, do you get better quality as a result of dvd ripping rather than vdo capturing it thru the use of a capture card?
thanks in advance...
Yes you'll get better results from ripping over captureing. It may take longer. Make sure you use a good video encoder. TMPGENC, Cinemacraft,Panasonic,Honestech are a few. Tmpgenc is free or was free anyway i think they produce retail versions now. www.tmpgenc.com
BD Rip worked only once, now can't rip BDs successfully
By thestrangebrew in forum Blu-ray RippingReplies: 2Last Post: 1st Apr 2012, 09:30 -
hd-dvd mkv rip comparison vs hauppauge hdpvr capture in 720p mode
By yoda313 in forum Capturing and VCRReplies: 3Last Post: 21st Aug 2011, 05:14 -
how to rip the dvd ????
By kathir. in forum DVD RippingReplies: 10Last Post: 29th Jul 2011, 09:44 -
Can't rip already backed up DVD, tried imgbrn, DVD shrink, DVD decrypter...
By perceptionist in forum DVD RippingReplies: 10Last Post: 27th Sep 2010, 00:52 -
my rip spec hell - from a ts. folder to rip specs - how?
By marinebc11 in forum MacReplies: 5Last Post: 26th Nov 2007, 21:28
