Is there any freeware that will convert BR to MKV at full bitrate like MakeMKV?
Not really,the evaluation period ends and you can't use it unless you buy. I tried the latest version and it won't work.
Go to their site and check. As far as I knew all you had to do was re-insert the new months codes. There is discussion there that sometimes problems occur with the process. The forum there will indicate if the Beta stage is over.
Tony -
This is statement is completely inaccurate.
At present MakeMKV is in beta and as such you can visit the forums to obtain a registration code that will allow continued use of the product at no cost. At some point this will be discontinued but the author has been doing this for a long time now. The DVD ripping capabilities will remain free forever, however.
With respect to any other product doing what MakeMKV does for free? I'm unaware of any product that will remove Blu-ray protections and convert to MKV for free. Your best bet would be to look for a program that can convert to MKV but use something like AnyDVD HD to remove the protections.
makemkv
By maxone71 in forum Blu-ray RippingReplies: 2Last Post: 5th Feb 2011, 06:55 -
Trying to use MakeMKV
By Humbug in forum Blu-ray RippingReplies: 4Last Post: 7th Nov 2010, 09:14 -
MakeMkv help
By razl in forum Newbie / General discussionsReplies: 0Last Post: 29th Jun 2010, 22:35 -
MakeMKV
By magmo in forum DVD RippingReplies: 1Last Post: 10th Nov 2009, 12:59 -
Using MakeMKV
By johnc10 in forum SubtitleReplies: 0Last Post: 6th Jun 2009, 06:52
