I'm not too sure if it belongs here but I figured I'd try.
I'm currently timing a series and I'm looking for a media player that shows milliseconds...
Up until now I timed 2 episodes using Windows Movie Maker because both files were AVI it came out great.
Now I have the rest of the episodes which are MP4's and WMM doesn't work with those so I can't use it.
I tried GOM player, VLC, WMP and no luck.
I tried timing with Aegisub but I'm not good with all of the software so it came out a mess, I prefer the old fashioned txt file method.But I really need software that shows milliseconds!!
Can anybody please help me?
(if it doesn't belong to this Forum please delete it)
Thanks I tried it but...it crushed because it can't play H.264 well (that's what the error message said anyway):/
Any more suggestions? -
If you are using ffdshow for mpc, you can checkmark the avisynth option and type info() (you need avisynth installed)
Or you can use avisynth separately in avspmod or vdub and type info() . IMO this is preferred, because you have the choice of a frame accurate source filter instead of directshow which is use by mpc . Directshow is not necessarily frame accurate and can "lose its place" especially on seeks . avspmod actually lists the time in ms at the bottom without info()
e.g
FFMpegsource2("video.mp4", atrack=-1)
Info()
You can also play the .avs directly in mpc if you need to hear the audio timing . This way it's routed through ffms2 instead of directshow
Player which shows time in milliseconds?
By Charmer in forum Software PlayingReplies: 2Last Post: 8th Aug 2009, 06:11 -
1280x720 50 fps capture shows as 640x360 in media player
By bc55 in forum Media Center PC / MediaCentersReplies: 2Last Post: 28th Dec 2008, 14:57 -
Looking for Media Server/Player for DVD movies/TV shows
By jet757f in forum Newbie / General discussionsReplies: 0Last Post: 6th Mar 2008, 14:20 -
LCD Projector Shows a DVD as Blank When Using Windows Media Player 10
By jetset in forum Newbie / General discussionsReplies: 7Last Post: 31st Aug 2007, 15:44 -
Baffled!! Titlewriter shows nothing but DVD Player shows Movie Name
By Subhash in forum Authoring (DVD)Replies: 16Last Post: 25th May 2007, 12:02
