Hi,
I have some stills and video footage that I want to put on a DVD and have a menu that allows me to choose to either watch a slide show of the stills or watch the footage. I have both premier pro and encore CS3.
How can I do this (always assuming it's possible).![]()
You didn't say in what format the video is, but DVDSlideshowGUI together with GUI For DVDAuthor should be able to do what you want.
You will have to create a video of the slideshow (DVDSlideShowGUI, as suggested above, is a good start). You can then author this video, and the other video footage, as separate titles on a disc using Encore (or, as suggested above, GUIForDVDAuthor).
Read my blog here.
Thanks,
Sorry for taking so long to get back with a reply to you but i've been away.
Regards.
dvd w/ video & picture slide show
By hymnatr in forum Authoring (DVD)Replies: 2Last Post: 20th Dec 2008, 11:51 -
DVD Slide Show Duplication
By KLouis22 in forum Newbie / General discussionsReplies: 3Last Post: 28th Aug 2008, 08:27 -
slide show video with proshow producer to avchd on blu ray disk
By LEONESVIZZERO in forum Authoring (Blu-ray)Replies: 1Last Post: 21st Apr 2008, 04:39 -
Adding slide show to a movied DVD
By leungf in forum Authoring (DVD)Replies: 2Last Post: 6th Sep 2007, 09:55 -
How to capture stills from a Video DVD slide show?
By riti in forum Newbie / General discussionsReplies: 3Last Post: 12th Jun 2007, 02:26
