I have being trying to get Avisynth64 running on Windows XP x64. I have installed Avisynth v2.5.8 which setup the correct directory structure in C:\Program Files (x86), and all the relevant 64-bit files have been copied to their correct locations in plugins64 and system32. The avisynth.reg file has also been imported into the registry. As a test I created a test avs file called version.avs, that contains the version() function. When I open version.avs in 64-bit VirtualDub, I get the following error message:
"AVI Import Filter errorunknown) (80040154)"
The same procedure works OK when using Win7 x64, so there may be a compatibility problem with avisynth64 which was compiled using the Win7 SDK in Vista compatibility mode.
Has anyone had any success in running Avisynth on XP x64?
			Closed Thread
	try the avisynth forum --
	Please don't post everywhere. Contiunue in https://forum.videohelp.com/threads/338532-AviSynth64-on-64-bit-XP?p=2103718#post2103718 .
  64-Bit Vegas Pro 9 fails to open 64-bit UT Video Codec PackBy Smells_Like_Feet in forum EditingReplies: 1Last Post: 2nd Oct 2011, 16:14
  AviSynth64 on 64-bit XPBy w2kpro in forum EditingReplies: 3Last Post: 21st Sep 2011, 09:56
  LAME 32-bit or 64-bit in EAC under Windows 7 64-bit?By flashandpan007 in forum AudioReplies: 1Last Post: 12th Apr 2011, 10:40
  Vista Home Premium x64 (64-Bit) vs x86 (32-Bit)By Shibblet in forum Media Center PC / MediaCentersReplies: 8Last Post: 30th Sep 2008, 18:42
  Making 32-bit VFW-ACM codecs available to XP 64-bit Edition.By gastorgrab in forum EditingReplies: 5Last Post: 19th Aug 2007, 12:12
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
