I'm using Macbook, iGrabber USB capturing device, Sony EVO-250, and Geniatech iGrabber software.
My video capture software doesn't seem to give me many options, so I'm considering H.264 compression. Figure I'd do this at 640x480 and 29.97 frame rate and then deinterlace later on. Not too sure about key frame or data rate.
My main priority is to transfer them to my external hd with good quality. Disk space isn't an issue.
What are your thoughts, criticisms, etc?
Your advice is appreciated!
I thought it would give the video a cleaner appearance? Though, I think it reduces the quality, does it not?
Thanks for your help! -
Indeed, it does. I quote from lordsmurf's excellent video guide:
Read more: http://www.digitalfaq.com/guides/video/capture-understand-sources.htm#ixzz1WiAF0dfj . Scroll halfway down the page to read the article "Interlace vs. Progressive vs. De-Interlace" for an explanation and sample pics."De-interlacing loses data. It's that simple. A de-interlace basically throws away parts of the video signal or blends it together with other parts of the video signal. It destroys interlaced footage. The only use gained by de-interlacing is to remove combs on a progressive display that has no access to on-the-fly de-interlacing software or hardware."Last edited by sanlyn; 20th Mar 2014 at 18:25.
http://www.kiva.org/about -
'Test card' video for optimum settings?
By CompVid in forum Software PlayingReplies: 6Last Post: 22nd Dec 2011, 14:04 -
Optimum x264 encoding settings
By zammil in forum Video ConversionReplies: 27Last Post: 18th Dec 2010, 01:32 -
Optimum Ripbot settings for HD video quality during conversion
By mario595 in forum Blu-ray RippingReplies: 22Last Post: 12th Apr 2010, 14:28 -
Low quality video on high resolution screen, improve video quality?
By Nitrius in forum Software PlayingReplies: 4Last Post: 29th Dec 2008, 14:38 -
M2PMCEncoderZX optimum settings
By Kalash109 in forum DVD RippingReplies: 0Last Post: 30th Nov 2007, 13:52
