Avidemux can do a great many things.
The problem is that I want to do very basic stuff and can't find how to do it.
I need to:
1. join hundreds of jpgs together
2. Alter the duration of each jpg on the timeline. (or equivelant way to change the duration) I don't see a timeline but I'm sure avidemux has a way to alter the duration.
3. Add subtitles and place them WHERE I WANT
4. import these jpgs into different groups (like subdirectories)
This is a sample of one of my movies. I made it in mov moviemaker. However my movies are getting to big for it
http://www.youtube.com/watch?v=eSPX5sjVYBc
Not really the program to do all of this.
Try DVD Slideshow GUI and a conversion progam such as autoGK if you need to make an avi from that. -
DVD Slideshow GUI looks great! thank you.
One thing - is doesn't support bmp. Do you know of a program that will do a mass conversion (100 files) from bmp to jpg? -
VirtualDub can import a numbered series of jpeg, bmp, or png, or tga files. You can set the overall frame rate with Video -> Frame Rate... You can use the Copy/Paste function to duplicate particular frames (ie extend the duration of a frame). You can import SRT subtitles and hard code them into the output file.
Mot really a question for a video forum but.....
The only program that I know that does batch processsing of image files is Photoshop. I am sure that there are others.
Even if you have only a hundred or so there is no so much time involved in doing them manually through Windows Paint. Or better still, create them in another supported format in the first place. -
Avidemux
By BaPW in forum EditingReplies: 7Last Post: 24th Jan 2012, 23:22 -
Avidemux aspect ratio question [from newbie to Avidemux]
By ANOther1676 in forum EditingReplies: 1Last Post: 20th Jan 2012, 20:07 -
I need help using AviDemux
By hardy in forum Newbie / General discussionsReplies: 4Last Post: 19th Jul 2010, 09:11 -
Avidemux
By jjis in forum Video ConversionReplies: 1Last Post: 23rd Nov 2009, 17:38 -
AviDemux....again...
By diablo_jones999 in forum Newbie / General discussionsReplies: 5Last Post: 10th May 2008, 08:31
