I converted a mpeg file to an ISO file using Img burn. How I convert this mpeg or ISO file to DVD-Video format so I can play it on my DVD player?
One way is to mount the ISO in a virtual drive, like Slysoft's free program called VirtualClone Drive.
Then use the mounted ISO file as input into AVStoDVD. If you know that the specs of the mpeg file are already dvd-compliant, look in the Preferences in AVStoDVD, and open the audio and video tabs. Put a check mark in the boxes to keep dvd compliant audio and video streams. This will insure that they are not reencoded, and retain original quality. If either are not compliant now, AVStoDVD will convert them so that the output will work in a dvd player.
You then burn the resulting dvd-video to a disk with ImgBurn. AVStoDVD can be set up to burn automatically with ImgBurn if you wish. -
It asked do I want to index this. I said yes, and it stated that the MPEG indexing failed. How important is it to index it? I ended up saying no when I tried to add the title again.
Can I burn or create the DVD_Video directly to my real computer dvd-drive? -
Guide for burning dvd-video to a single layer dvd: http://forum.imgburn.com/index.php?showtopic=4632
How can I create IFO + BUP files for a VOB file?
By mac&me in forum MacReplies: 3Last Post: 4th Dec 2010, 02:06 -
Can I create an .IFO file from .VOB files?
By Madcap in forum DVD RippingReplies: 7Last Post: 15th Aug 2010, 14:57 -
Want To Mux MPEG-2 Video With .WAV to Create .VOB
By judicata in forum Newbie / General discussionsReplies: 2Last Post: 12th May 2010, 16:07 -
create video_ts from vob file
By stockton209 in forum Video ConversionReplies: 1Last Post: 7th Jan 2010, 17:33 -
How to cut VOB-file and create DVD from VOBs?
By john999UPR in forum Newbie / General discussionsReplies: 1Last Post: 19th Mar 2009, 10:07
