I know that occording to Wiki there's MPEG-2 video streams that contain I, P, and B frames and MPEG-2 video streams that contain only I and P frames. However I also recall reading somewhere that the MPEG-2 standard also supports MPEG-2 video streams that consist ONLY of I-frames. So I'm wondering what video conversion software exists that supports outputting I-frame only MPEG-2 videos?
Results 1 to 9 of 9
Note that I frame only MPeg2 has no temporal compression so for quality you need to use 2x-6x bitrate.
What is your source?Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
No. I-frames encode the entire picture like a JPEG image. So, for example, in a talking head shot an all i-frame video has to encode the static background as well as the moving speaker in every frame. With predicted frames it only has to encode the part of the picture that changes at each frame. Maybe just a few bits to represent the speaker's moving lips. Or in a panning shot, predicted frames can say "shift the entire image left by 4 pixels*, add fill in the right edge with this" -- much less information than encoding the entire frame. So all i-frame encoding takes a lot more bitrate. It's the whole reason predicted frames were invented.
* In practice, MPEG 2 does this on 8x8 blocks, not the entire picture.Last edited by jagabo; 31st Aug 2011 at 21:34.
Thanks for the explanation. That makes more sense.
Which should I use for increased quallity, Variable Bit Rate, or a Constant Bit Rate with the constant rate set fairly high? Also will this difference between VBR and CBR effect "Iframe only" video, or is it only for when P and B frames are used? -
What type of source are you encoding?
I-frame only is typically used to speed editing/effects computation, for example digital intermediates used in media production.
For GOP based formats, a high CBR based format is often used for acquisition (e.g. camcorders, animations). These may be edited as is (e.g. HDV, XDCAM formats), or converted to a digital intermediate. As an example, HDV is MPeg2 with 15 frame GOPS and CBR of 25 Mb/s. When converted to an I frame only digital intermediate like Cineform, the bit rate (and file size) increases 3x-5x.
After editing is finished, the final product is VBR compressed for the distribution format (e.g. DVD, Blu-Ray, TV broadcast) to maximize compression while maintaining adequate bit rate for high motion complex scenes.Recommends: Kiva.org - Loans that change lives.
CBR can be easier on an editor than VBR. At very high bitrates CBR and VBR quality are similar.
how to make a video "stickin" to a certain view (frame)?
By Srivas in forum EditingReplies: 17Last Post: 14th Jan 2012, 10:11 -
MEncoder outputs "could not find matching colorspace"
By codemaster in forum DVD RippingReplies: 0Last Post: 21st Sep 2011, 19:20 -
Was it the iphone that replaced the word "program" with "application"?
By yoda313 in forum Off topicReplies: 6Last Post: 16th Mar 2011, 09:52 -
"Failed to read video frame"
By jva1254 in forum EditingReplies: 1Last Post: 25th Sep 2009, 06:59 -
HCenc "Invalid MPEG-2 Frame rate" error.
By Maikeru-sama in forum Video ConversionReplies: 24Last Post: 8th Jul 2008, 19:09
