Hey, I've been trying to rip our (legal, store-bought) DVD of Disney-Pixar's "Up", so I can make a back up copy. I have successfully used MTR 4.0 to rip it (it suggests using the 'Rip And Rebuild' setting for this disc, so I did), but when I go to burn the TS folder in Toast, it turns out to be an 'oversized disc', so I can't make the contents fit onto a DL+R DVD. Any way to fix this or get around the oversize problem? Thanks.
By the way, if it is helpful, I am running Mac OS X 10.5 on a G5 PPC computer.
P.S. Sorry if this is in the wrong area. I'm not sure whether this goes better in "Mac" or in "DVD Ripping", so I just tried to go by the descriptions for guidance.![]()
the Disney stuff is always a pain to back up, sounds like you might need to re-rip with a different app or you might need a copy of DVD2one and some info on which sections you can copy..try the MTR forums for more detailed info..i also recommend getting Mac DVDRipper Pro
Need help: Trouble importing/capturing a "locked IFO" on DVD
By mattday79 in forum Video ConversionReplies: 3Last Post: 1st Jan 2011, 17:29 -
By mattday79 in forum Capturing and VCRReplies: 3Last Post: 1st Jan 2011, 13:41 -
Samsung R155 DVD Recorder - "Recorded" or "Blank"?
By mhamini in forum DVD & Blu-ray RecordersReplies: 3Last Post: 6th Feb 2010, 19:01 -
i have trouble with "Cyberlink PowerDirector6" capture from Turtl
By Chief ADFP in forum Newbie / General discussionsReplies: 6Last Post: 7th Apr 2008, 19:09 -
Editorial: Why "HD DVD" Is Thumping "Blu-ray Disc"
By Specialist in forum Latest Video NewsReplies: 146Last Post: 16th Feb 2008, 08:08
